compression readings
Old Aug 26, 2009 | 08:59 PM
maestrouk's Avatar
maestrouk
Default compression readings
what should each cylinder have as compression on a mk 4 escort turbo standard block???
and how would a car run if a piston has a damaged ring ??
Old Aug 26, 2009 | 09:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Fresh engine should be around 12bar (175psi), if one of your piston rings had broken up it would be like it was running on 3.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Iain Mac
Sep 30, 2015 09:39 PM
