turbo is not well
Old Aug 26, 2009 | 08:48 PM
maestrouk's Avatar
maestrouk
Default turbo is not well
my escort rs turbo starts aruns fine with no smoke i take it for a spin , put my foot down it boosts then splutters big bang and a cloud of blue smoke, just had a recon turbo fitted so what could it be ???
Old Aug 26, 2009 | 08:56 PM
LHD220Turbo's Avatar
LHD220Turbo
you sure the motor is timed up right?
not running too much boost?
Old Aug 26, 2009 | 09:01 PM
maestrouk's Avatar
maestrouk
Default not well
well it runs and revs perfect and drives ok just once the tubo kicks in on release i wound down -31 and still doing it ?
Old Aug 26, 2009 | 09:03 PM
andy130's Avatar
andy130
its hard to say mate, whats the spec of it?
Old Aug 26, 2009 | 09:06 PM
maestrouk's Avatar
maestrouk
Default spec
standard, all ive dne is put a recon t3 on it like i say no smoke at all on driving like miss daisy the second i turn into lewis hamilton it spluttes big pop and blue smoke then clears again
Old Aug 26, 2009 | 09:08 PM
jammy86's Avatar
jammy86
What do you mean wond it down? To reduce boost you need to make it longer not shorter.
JAmes.
Old Aug 26, 2009 | 09:10 PM
maestrouk's Avatar
maestrouk
Default wound it down
JAmes.
yeah thats just my way of saying winding te boost down mate by screwing the arm out longer
Old Aug 26, 2009 | 09:13 PM
andy130's Avatar
andy130
did it do this before the turbo let go? could be leads,plugs
Old Aug 26, 2009 | 09:14 PM
maestrouk's Avatar
maestrouk
i bought the car with the turbo gone so iwouldnt know ill give that a try
Old Aug 26, 2009 | 10:44 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
sounds timing related to me.
Old Aug 27, 2009 | 12:07 AM
Chopshop85's Avatar
Chopshop85
Did you get the turbo re-coned? or bought it re-coned?
could be one of many things, speaking from experience of similar symptoms
weak spark
timing's out
-31 actuator on std ecu (too much boost)
blocked/squashed vacuum hose to the ecu. ( a favourtie of my car )
Old Aug 27, 2009 | 06:04 PM
maestrouk's Avatar
maestrouk
weak spark
timing's out
i got it reconed ill give what yuv said atry an i will letyou kno how i get on thanks for the info
Old Aug 27, 2009 | 06:19 PM
Chopshop85's Avatar
Chopshop85
ok man, let us know if theyre any break throughs
Old Aug 29, 2009 | 02:27 PM
maestrouk's Avatar
maestrouk
right running better i wound out te actuator but now it seems t b over boostin all te time ?
Old Aug 29, 2009 | 08:15 PM
Chopshop85's Avatar
Chopshop85
Have you got a chipped ecu in it?
Old Aug 29, 2009 | 08:30 PM
maestrouk's Avatar
maestrouk
yes
Old Aug 29, 2009 | 08:44 PM
Chopshop85's Avatar
Chopshop85
hmm could be one of many other things then. i would strongly suggest winding the boost off completely until you can get a tuner to have a look at it. heard way to many sob stories of people who try to do a bit of home tuning and a few weeks down the road picking bits of theyre engines up off the road.
Old Aug 30, 2009 | 08:18 AM
maestrouk's Avatar
maestrouk
Smile
top stuff ta
Old Aug 30, 2009 | 12:19 PM
andyuk's Avatar
andyuk
drop it up to mine ant i can have a look for you,
Old Aug 31, 2009 | 03:32 PM
maestrouk's Avatar
maestrouk
Default turbo
text me were your livin now ill drop it in
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
