zetec engine ques
Old Aug 26, 2009 | 08:19 PM
harveyrst's Avatar
harveyrst
Smile zetec engine ques
hi ive got a 1.8 gti donor car and its got air con pump and power steering pump i wnt to remove these what alternater/water pump belt can i use ? . and can iuse the zetec box in a mk3 escort with slight mods ?
Old Aug 27, 2009 | 03:26 PM
Removing the air con is no problem, as you just use a std non aircon belt, but removing PS pump as well, would most likely mean the easiest way would be remove the things then measure the length, then scour the books to see the nearest belt size to what you need.
Zetec boxes can be used, but sure they require mods to chassis rail.
JoeyBoyden
Jan 4, 2024 02:36 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
