mk4 escort efi and mfi heads and cams....
Old Aug 26, 2009 | 08:01 PM
Toe Knee's Avatar
Toe Knee
Default mk4 escort efi and mfi heads and cams....
From memory the heads are the same?! but are the cams the the same on the efis and the mfis by any chance?!
ta
Old Aug 27, 2009 | 04:36 PM
ob1marty's Avatar
ob1marty
not to sure the head is different injectors on efi go in head but ya can get a conversion plate not sure about combustion chambers , think pre 86 heads have different chambers aswell
Old Aug 27, 2009 | 04:39 PM
xrmalin's Avatar
xrmalin
There the same ford only list one part number for a 1600 cvh cam shaft
The heads are the same aswell bar the injector recesses in the inlet side
mark
Old Sep 9, 2009 | 02:59 PM
puliukk0's Avatar
puliukk0
mark
Sorry but:
1.3, 1.4, 1.6 Carbs, and 1.4i - Got same
1.6 (Weber 2V), 1.6MFi, RS Turbo - Got same
1.6 EFi have own cam. Thats tightest, pretty good to RST.
I checked these at Ford Microcat. They got many cams, not 1.
These are the parts what you get at Ford now, there is old (original) cams where is some different like 1.4, 1.6, XR3i etc.
These i got in internet:
-------Inlet° Exh.° Lift "
1.4C - 225 / 221 / 0.376
1.6C - 221 / 225 / 0.376
XR3i - 224 / 220 / 0.396
86-on - 216 / 228 / 0.396
+ RS Turbo, and EFi camshafts.
If im wrong, please tell me. And sorry about my bad English
Old Sep 9, 2009 | 03:05 PM
puliukk0's Avatar
puliukk0
And heads:
<- 86 = Hemi design
86 -> Carb = Lean burn design
86 -> Hemi design
EFi head (Hemi) but injector holes.
http://www.pumaracing.co.uk/CVH.htm
Here is some info.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
EoinXR3
Sep 7, 2015 05:44 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
