Fuel Accumulator on EFI causing problems?
Old Aug 25, 2009 | 01:38 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Fuel Accumulator on EFI causing problems?
I've recently finished building my car back up but am having slight problems. Basically it started misfiring at high loads, cutting out completely when hot and seemed to lean out badly when going downhill if I took my foot off the throttle.
The car has had a group A coil, new leads, plugs, dizzy cap and rota arm so it cant be a spark problem.
The fuel pump was also replaced for a Focus WRC pump thats a higher output than a Bosch 044 so its not the pump.
What I'm wondering is could it be the fuel accumulator causing this which I desided to keep when I went to MFI? I was told to keep it as it helps stop fuel surge etc but can they fail and cause these sorts of problems?
Old Aug 25, 2009 | 01:39 PM
muz's Avatar
muz
Wye Valley Hardcore
Also all the Fuel lines were replaced with brand new braided lines and it had a new Mahle fuel filter so cant see it being a blockage?
If I ditch the Accumulator can I still keep the MFI tank and pump?
Old Aug 25, 2009 | 03:52 PM
I have no accumulator on mine and i have the standard tank and pump ,check the tank is not dented which may cause a blockage
Old Aug 25, 2009 | 03:58 PM
muz's Avatar
muz
Wye Valley Hardcore
I never noticed a dent in the tank when I took it off and painted it Dave
Old Aug 25, 2009 | 04:00 PM
ok just a thought, try the accumulator
Old Aug 25, 2009 | 04:06 PM
muz's Avatar
muz
Wye Valley Hardcore
Might just buy a new fuel tank and bypass the accumulator, see if it sorts it. Just seemed weird how it only happend going down hill off throttle, when the car was warm etc.
Old Aug 25, 2009 | 05:57 PM
rstdave's Avatar
rstdave
Have no accumulator on mine either, junked it when i went efi as it's not needed.
Old Aug 25, 2009 | 10:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Old Aug 25, 2009 | 10:36 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
no accumulator here either, external swirl pot though.
Old Aug 26, 2009 | 10:20 AM
JesseT's Avatar
JesseT
I always kept the accumulator on my cars with MS.
No problems if the injectors don't leak.
Old Aug 26, 2009 | 10:29 AM
Antti O's Avatar
Antti O
I dont have accumulator either and standard fuel pump is well enough over 250bhp proven.
I suggest you first find out which is the problem spark or fuel before replacing parts
EoinXR3
Sep 7, 2015 05:44 AM
muffster
13
Sep 3, 2015 09:40 PM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
