2wd cosworth sump gasket
what to go for?
need to change mine, looks like its been blown out.
stage 3 spec car. whats a good quality one to go for, dont want to be changing the gasket again in the near future.
Hi,
i'm doing the same, with a 2wd sump gasket, got both cometic & stardard ford OE gaskets from woodford + new ford OE front and rear crank seals.
which one is best to use..?
should i use any loctite black on the sump gasket.. or not use anything.?
thanks.
Manoj
thanks.
Manoj
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Aug 14, 2015 07:29 AM
lockie
Jul 31, 2015 10:03 PM
