RS Turbo drive shafts difference ??
Old Aug 24, 2009 | 05:20 PM
Sideways Si's Avatar
Sideways Si
Default RS Turbo drive shafts difference ??
Are all drive shafts used on the mk3 and mk4 Escorts the same ??
Thanks in advance
Old Aug 24, 2009 | 05:28 PM
kidsRS's Avatar
kidsRS
"Ill check the stock"
Probably
Old Aug 24, 2009 | 05:35 PM
StephenC's Avatar
StephenC
..BS Motorsport..
the rs ones had a ribbed section for the abs belts to go on but theyre still the same length and shit. AFAIK
Old Aug 24, 2009 | 05:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
On the 1.6 yes, but the 1.3, 1.1, were smaller diameter IIRC.
Old Aug 24, 2009 | 07:38 PM
jodyhoare's Avatar
jodyhoare
+1
Old Aug 24, 2009 | 08:31 PM
JesseT's Avatar
JesseT
Early ones had a ball type joint in the inner end as well as in the outer. Later ones are with a tripod as the inner joint.
RockinRein
Aug 19, 2015 07:08 PM
muz
Aug 16, 2015 12:57 PM
A.t.p
Aug 15, 2015 11:37 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
Churtz
Aug 3, 2015 08:19 PM
