Warping Brake discs
Old Aug 24, 2009 | 09:39 AM
It's Czech Mate's Avatar
It's Czech Mate
Default Warping Brake discs
A mate of mine has a Passat Estate, and he was telling me in the pub how he keeps warping his brake discs every few months. He has all new bushes etc and new wheel bearnings but it keeps doing it. I asked him what discs he was using and he said el cheapo unipart ones as he cant afford to replace OEM so often
I suggested that the unipart discs might be the problem? Or some kind of wheel bearing alignment problem?
What do we think?
Old Aug 24, 2009 | 09:44 AM
rog's Avatar
rog
Shite quality discs is what I think, surely he needs to realise that if he spends that extra £100 or so he could get drilled/grooved aftermarket EBC discs and it would work out cheaper that X many sets of Lidls brakes.
Old Aug 24, 2009 | 09:48 AM
Less.'s Avatar
Less.
having a mid life crisis
Unipart thats the problem fitted them to my old erst as stop gap and they warped in no time
Old Aug 24, 2009 | 10:03 AM
C4llyT's Avatar
C4llyT
But they don't warp, pad material stuck to them is what causes the wobble.
Maybe it's a sticky brake that's the issue, or his driving style.
Old Aug 24, 2009 | 10:07 AM
daviddunlop83's Avatar
daviddunlop83
When i had my ST170 the standard ford brakes warped all the time but that was due to driving it like a hooligan lol and getting them glowing like this:-
Also the mondeo i have with similair size 300mm discs, i replaced with genuine ford ones and these are also slightly warped also.
When i had the ST i put tarox discs on and it was fine for 30k with hard braking.
Id def say the cheaper discs wont last long at all.
Old Aug 24, 2009 | 10:12 AM
It's Czech Mate
They are warped, he's had a guage on them
Old Aug 24, 2009 | 10:13 AM
It's Czech Mate
Seems unanamous that his budget discs are shit then,
I'll get killed if he spends out on some decent ones and it happens again!
Old Aug 24, 2009 | 10:18 AM
YOREVOL's Avatar
YOREVOL
YOREVOL
I have heard that the hubs can warp causing warped disc symptoms.
But isnt he getting the discs under warranty.surely he cant be doing too many miles in this time
Old Aug 24, 2009 | 10:21 AM
GUZZLER's Avatar
GUZZLER
try getting the disks skimmed on the car, that helps with evo's when the hubs distort.
Old Aug 24, 2009 | 10:31 AM
C4llyT's Avatar
C4llyT
The pad deposits would obviously show runout on the discs....
Old Aug 24, 2009 | 10:51 AM
It's Czech Mate
Thats a pretty good idea actually!
Old Aug 24, 2009 | 11:06 AM
focusv8's Avatar
focusv8
Driving style can warp /crack discs.
Heavy braking , then standing at traffic lights or junctions with the footbrake on.
The area of disc under the pads doesn't cool as quick as the rest.
Old Aug 24, 2009 | 11:10 AM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Is he cleaning the hub face before fitting the disc? A small bit of crap under the disc can cause a surprising amount of runout.
Old Aug 24, 2009 | 11:12 AM
GTi-R23's Avatar
GTi-R23
The ladies love it French
Poorly balanced wheels can lead to this effect also, but if you say he's had a gague on the discs and they aren't warped then it's probably not the issue
Old Aug 24, 2009 | 11:16 AM
Neil S's Avatar
Neil S
I'd go with cheap pads and discs causing the problem. As said, 'warping' is caused by uneven build up of pad deposits on teh discs.
EBC will probably be worse!!
I'd be putting OE ones on for sure!
Old Aug 24, 2009 | 11:23 AM
It's Czech Mate
Right, i'm going to tell him to either get them skimmed or to fit OEM discs and pads, making sure the hubface is nice and clean.
Thanks for all the opinions guys
Old Aug 24, 2009 | 11:26 AM
Neil S's Avatar
Neil S
Good call, give them a skim then put some decent pads on
Nov 1, 2015 06:53 PM
locum8
Oct 1, 2015 01:50 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
