filling gearbox up
Steve, the haynes manual is in pdf half way down that page I linked to
http://www.siipicossu.com/manuaaleja/manuaalit.htm
I bought this one:-
http://cgi.ebay.co.uk/Draper-Oil-Suc...QQcmdZViewItem
Makes it so much easier tho the pipe is too large for ford box's so i had to put a smaller bit of tube in the end to make it fit. Works perfect now
iv always managed to fill mine up fine with the tube on the end of the bottle of oil, i just approach from underneath, put the tube into the box, then lift the bottle upwards and away it goes. obviosuly if u try the same from above u will lose half the bottle in the engine bay before you get the tube into the box
chowfornow
14
Jan 5, 2019 09:01 PM
SMILER258
Sep 28, 2015 09:04 AM
