1.8D and TD wiring??
Old Aug 23, 2009 | 07:57 PM
twolitrepinto's Avatar
twolitrepinto
Default 1.8D and TD wiring??
Hi i have a mk6 escort van 1.8d
i have got a rotten mk6 escort estate with a 1.8TD lump and box in it,
my van is 2001 and the car is a few years older, but the TD has an Air flow meter, air-con (pipes cut),
i want to use the air flow meter and everything from the TD exactly as it is, other than the air con. i know i have to remove the PAS pump, brackets and swap the PAS pump from my engine.
i have pulled all of the wiring loom out of the TD, and the ECU from the passengers footwell, but on the drivers side bulkhead under the bonet there is 3 plugs, black, grey and small one, my van has the same big black plug that does the engine bay loom, but it has 10 wires in it and the TD has 12.
does this mean that i hve to change these 3 plugs and all the wiring going to the fusebox aswell?
i know the exhaust is different i got that sorted,
the TD gearbox has a speedo cable and the van has electronic speedo with digital clocks, i dont really want to put the older clocks in so i will need to somehow wire that part of the van loom back into the other loom?
on the side of the heater box there is another 2 little boxes with plugs going to them, im guessing that these are for air con and i can just ignore them? there is a vacuum pipe going to one of them, and a metal strap running across the the back of the heater box, the van has none of this. i could do with a wiring diagram for both really if anyone has them i know its a long shot.
if anyone has done this conversion i would appreciate some help with these issues.
thanks
Old Aug 24, 2009 | 12:29 PM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
looks like the van is a newer loom etc
might have trouble with the wiring of the clocks etc as they'll be wired to the ecus of the van ??? being electronic etc
Old Aug 25, 2009 | 12:10 AM
twolitrepinto
well im hoping they dont run through the ECU and the wires go from the clocks, through the loom to the gearbox, or anywhere apart from ECU.
if they do go to the ECU i might just leave my vans ECU wired in somewhere just for the clocks sake and just leave everything else off of it?
if it cant be done il have to live with the old style clocks.
any wiring diagrams of the 2 looms would be bloody lovely!
anyone got a haynes manual for either one please be kind enough to upload some wiring diagrams
thanks
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
cossie brad
Sep 29, 2015 02:38 PM
IainRS1700T
Sep 25, 2015 06:44 AM
