Mechanical guru's opinions please
Old Aug 23, 2009 | 07:20 PM
wayne thomas's Avatar
wayne thomas
Default Mechanical guru's opinions please
Canvasing opinions here guys,
A mate has a renault 19 (that's only the start of his problems though). On his way to work on Friday the cambelt snapped whilst doing about 50mph in top on the motorway, he was recovered to a local garage who have suggested fitting a new belt and trying to start it. The thing is, the lad is skint and can ill afford chucking a couple hundred at a gamble, the car a 1.4 8valve on an S plate so is worth 2 quid and will be scrapped if there has been any contact internally as a result of the belt letting go(no point throwing good money after bad).
In summary then.
Can anybody state with a degree of certain that there will have been some contact?
thanks guys
Old Aug 23, 2009 | 07:28 PM
KnoxyGtt's Avatar
KnoxyGtt
T34 just kicked in Yo
At 50 mph yeah i would say so lol
Old Aug 23, 2009 | 08:55 PM
Red16's Avatar
Red16
Me too... I'd be amazed if there hadn't been any contact to be honest.
Old Aug 23, 2009 | 11:50 PM
cjwood555's Avatar
cjwood555
Not quite the same engine i know, but a work mate had to have a full head rebuild after his went on a 1.2 16v clio, doing the same sort of speed and also in 5th....
Chris
Old Aug 23, 2009 | 11:54 PM
Teej's Avatar
Teej
Most likely, they are'nt a "safe" engine
Buy a new belt for a couple of ŁŁ, fit and check compression
Old Aug 24, 2009 | 12:15 AM
BigErn's Avatar
BigErn
it will have bent valves 100%
Old Aug 24, 2009 | 06:38 AM
john_p_b's Avatar
john_p_b
agreed, we run a fleet of various renaults and never escaped a snapped belt without internal damage. Spend the money on another car.
Old Aug 24, 2009 | 10:50 AM
Alvyn's Avatar
Alvyn
If the rest of the car's ok get a 2nd hand engine(cheap enough) changed the belt/tensioner while out job done!
Old Aug 24, 2009 | 12:35 PM
YOREVOL's Avatar
YOREVOL
YOREVOL
If the top of the engine is square then the valves will be bent.
I bought a clio like this repaired it for Ł150 +labour
Old Aug 24, 2009 | 02:20 PM
Yeh i would say it will have had valve to piston contact.The car isnt worth repairing.
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
20/20 vision
Sep 29, 2015 11:27 AM
