how do i identify what ecu + chip my 2wd saffy is running ?????
Old Aug 23, 2009 | 07:02 PM
bigd2's Avatar
bigd2
Default how do i identify what ecu + chip my 2wd saffy is running ?????
just bought my 1st saffy and been told its stage 3 etc etc , i bought it with a blown engine and am currently rebuilding her but am just finding my feet with it and would appreciate help with identifying the ecu + chip for starters and im sure ill be needing loads more help and advice in the next few months ,
cheers, Danny
Old Aug 23, 2009 | 07:17 PM
oldford's Avatar
oldford
For the ecu see the pictures at:
http://www.bigturbo.co.uk/main1.htm
Is there anything written on the ecu or the label on the chip?
Old Aug 23, 2009 | 07:40 PM
bigd2's Avatar
bigd2
just looked at the link and i think its a level 1 ecu , it has a yellow mixture screw and the transistors are screwed down , are these ecu's any good ?? if im looking at the right thing there is a sticker on the chip saying (sierra y/s 2 803/320) and hand written it says roy's and 3 on the sticker too ??
Old Aug 23, 2009 | 08:59 PM
Alvyn's Avatar
Alvyn
yellow co screw does normally mean it's a L1 which was used on some really early Sapp's but more common on the 3 dr! the other info you've said would suggest it's running 803's and good for 320 bhp at a guess!
Old Aug 24, 2009 | 06:43 AM
oldford's Avatar
oldford
I agree, 803 injectors and probably a 3-bar map sensor from an unknown source.
The only problem with a L1 ecu is that you can't have closed-loop lambda control and other fun things like launch-control and ALS.
Old Aug 24, 2009 | 10:57 PM
bigd2's Avatar
bigd2
thanks for that , ill prob run it for a bit whilst i run the engine in after the rebuild and then might start playing about a bit more
cheeRS , Danny
Old Aug 29, 2009 | 09:25 AM
Stu @ M Developments's Avatar
PassionFords Creator
Take care guys, the fact it says that on the sticker means nothing. I regularly get cars in after meltdowns with totally incorrect labels from the ebay copycats.
Old Aug 30, 2009 | 09:21 PM
martysmartie's Avatar
martysmartie
Neither can L6
Martin
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
13
Aug 31, 2015 06:02 PM
Toe Knee
Aug 23, 2015 08:31 AM
JasonPD
21
Aug 20, 2015 07:36 PM
