I want exhaust Pops and Bangs! :D
Old Aug 23, 2009 | 05:19 PM
puntogtkid's Avatar
puntogtkid
Drifter
Default I want exhaust Pops and Bangs! :D
I have currently got a sierra cossie 5 door sapphire, running a full stage 3 set-up, T34, greens, RS500 intercooler etc etc. running 350 BHP. But it doesnt sound as aggresive as i would like, i want to fit anti lag or launch control as i have heard this causes the pop, bang effect, LOL! but have been told it would snap my turbo shaft if fitted, is this true?
Old Aug 23, 2009 | 05:27 PM
jammerrs's Avatar
jammerrs
anti lag will unless you have a mar m 247 shaft
Old Aug 23, 2009 | 05:28 PM
puntogtkid's Avatar
puntogtkid
Drifter
where can u get them shafts from? and will launch control give pops and bangs?
Old Aug 23, 2009 | 05:32 PM
Less.'s Avatar
Less.
having a mid life crisis
No idea about the shaft but maybe have a word with stu at MSD about the anti lag
Old Aug 23, 2009 | 05:40 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
we can do mild set ups which can be used on a std turbo without to much bother as long as you dont run it for great lenghts of time.
Old Aug 23, 2009 | 09:00 PM
puntogtkid's Avatar
puntogtkid
Drifter
can anti lag be switched off and on a switch so to say then? and will a mild set up gimme what im after? its not really for performance enhancement just a bit of showing off tbh
Old Aug 23, 2009 | 09:10 PM
JTECH James
Passion for Fords!
yes, its switchable,even the mild does function quite well, but deffo gives you what yoiur after aswell lol.
we also do launch control which is also very loud! we normally wire this through the handbrake switch, so its active when the handbrake is on to pre load the transmission.
all you need is an L8 or P8, and our chip with als and lc activated!
Old Aug 23, 2009 | 09:16 PM
puntogtkid's Avatar
puntogtkid
Drifter
prices?
Old Aug 23, 2009 | 09:17 PM
JTECH James
Passion for Fords!
give us a ring tomorrow mate, and we can price up what you need,
it varys a bit on engine spec etc.
Old Aug 23, 2009 | 09:19 PM
james kiely's Avatar
james kiely
is all launch control preloaded like msd,s ,via handbrake james
puntogtkid's Avatar
puntogtkid
Drifter
ok chap, can i ask for ya james?
Old Aug 23, 2009 | 09:25 PM
JTECH James
Passion for Fords!
you can mate, but anyone will be able to help!
a few things to find out before you call,
ECU type,
Pectel or ford baby board in the ECU
Engine spec if modded, CR, head port size, turbo type, cam type, injector type, etc etc
if you have this data ready to hand it will speed things up a little
tankybaby66
Feb 6, 2016 02:24 PM
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
