3dr cosworth solid brake pedal
Old Aug 23, 2009 | 04:30 PM
r70at's Avatar
r70at
Default 3dr cosworth solid brake pedal
hi can you help,i have a solid brake pedal on a 3 dr cosworth? do you have a idea whats wrong?
thanks andy
Old Aug 23, 2009 | 05:47 PM
Alvyn's Avatar
Alvyn
check one of the fuses hasn't blown m8! the relays should be just above the pedals!
Old Aug 23, 2009 | 05:54 PM
BigErn's Avatar
BigErn
big 30A fuse under the glove box
Old Aug 25, 2009 | 12:40 AM
NUTS RuS's Avatar
NUTS RuS
Do they run a vacuum pipe off the servo ?
Old Aug 25, 2009 | 05:02 AM
Gav Diamond's Avatar
Gav Diamond
No vacuum pipe tony,
This sounds as said above the fuse on the right above the pedals there is a couple of relays there as well.
Used to get this on my car, the hand brake light would come on and you would get about 2 presses of the pedal then it would be solid, the cause on mine was water/rain leaking through under the fuse box and drip into the fuse holder as meantioned above.
original
Apr 28, 2026 05:20 PM
s1cab
Jul 26, 2018 06:11 PM
bigluke200
14
Sep 2, 2015 10:35 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
