Big end shell trouble, Any ideas?
Old Aug 23, 2009 | 03:54 PM
bigjim172000's Avatar
bigjim172000
Me Cossie Runs Atlast!!!!
Default Big end shell trouble, Any ideas?
Taken number 3 piston out my block today as i thought the rings had gone. Well they havent,
got this instead
Number 3 shells,
Here is number 1
Number 2,
Number 4,
The number 3 was well fooked, the metal had gathered i the sump as a small lump.
Doesnt even fit the conrod anymore.
The annoying thing is, this engine was only put together 1000 miles ago
Any ideas of the cause? Oil Pressure was fine.
Old Aug 23, 2009 | 03:57 PM
RS 5tu's Avatar
RS 5tu
Have you checked the crank, That could be worn?
Old Aug 23, 2009 | 03:59 PM
Red16's Avatar
Red16
Possibly oil contamination, oil galleries obstruction or incorrect bearing to crank clearance?
BigErn's Avatar
BigErn
Thats bad for 1000 miles. Did you get crank ground? Are the shells the correct size? Are they made for your engine not a lesser model?
bigjim172000
The crank was ground at the same time and the shells came from the same place.
All the other journals are fine except number 3 which is fooked
Old Aug 23, 2009 | 04:02 PM
bigjim172000
Everything was cleaned merticulosly. The oil was the best for the job and the filter was changed at 100 miles and new oil, then again at 500 miles.
Old Aug 23, 2009 | 04:04 PM
BigErn's Avatar
BigErn
what size was the crank ground to? Chek the shells, make sure they were correct size. Failng that its possible oil starvation. Have you checked the oil pump?
Old Aug 23, 2009 | 04:06 PM
Red16's Avatar
Red16
The shells from number 1 and 4 dont look very good either, look like theyve been marked by the crank as its rotated, definitely not what i'd be expecting from a 1000 mile engine tbh! The shells from number 2 look very similar although its hard to tell with the amount of oil thats on them in the photo.
Old Aug 23, 2009 | 04:08 PM
bigjim172000
Havent had the pump off yet. So pissed off im on the verge of selling it/breaking it. Cant remember what it was ground to but the shells were correct for what they said they had ground it to. I remember it at the time.
Old Aug 23, 2009 | 04:10 PM
bigjim172000
I agree but they hadnt marked the crank whereas number 3 has fooked it
Old Aug 23, 2009 | 04:13 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Was the oil pump new? Are there any other signs of damage to anything else? What do the sides of the pistons look like?
Old Aug 23, 2009 | 04:15 PM
BigErn's Avatar
BigErn
Get the oil pump off and open it up, that would be my guess.
Old Aug 23, 2009 | 04:19 PM
SteveB's Avatar
SteveB
My guess would be oil pump is defo fucked now.... Looks like debris in the engine after maching left behind
Old Aug 23, 2009 | 04:21 PM
borderfox's Avatar
borderfox
Not nice that.
It was hardy over fueling and fooked the oil up.
Old Aug 23, 2009 | 04:42 PM
Just get it in bits, and I'll pop over monday(24) so we can form a action plan, etc.
Old Feb 10, 2010 | 08:38 PM
mattman1234's Avatar
mattman1234
What made you suspicous,could you hear it,or was there swarf in the oil,
I'm worried about mine now
Old Feb 10, 2010 | 08:47 PM
mechanic28's Avatar
mechanic28
i too would check you oil pump looks like by looking at your other shells the whole lot was getting close to give it up!
Old Feb 10, 2010 | 08:51 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Last August
Old Feb 10, 2010 | 09:05 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Even if the crank had been ground and shells supplied, doesnt mean it had been done properly! or the shells were right....posability.
Old Feb 10, 2010 | 09:12 PM
stevostyles's Avatar
stevostyles
i have or had this problem iam still connecting hoses to try my new acl shells, but i was told you need the correct squash on the shells ie the rod caps torqued up right think it explains on youtube if you can find it ? if you look at my threads see what people said mate may help ?
Old Feb 10, 2010 | 09:14 PM
mattman1234
mine are acl shells
Old Feb 10, 2010 | 09:17 PM
stevostyles
also just to note mine wernt as bad as them shells but did notice 1 bolt seemed too loose so would have been only properly seated around the crank jernals
did you notice 1 bolt not quite as tight ?
Old Feb 10, 2010 | 09:19 PM
stevostyles
Originally Posted by mattman1234
mine are acl shells
i got mine off ebay 38.00 then went to our customers and he said shud av come to me i can get you them for 15quid
Old Feb 10, 2010 | 09:23 PM
stevostyles
agree getting sold the wrong size happens alot even with an experienced engineer supplying and turns out to be an expensive headache.
Old Feb 10, 2010 | 09:24 PM
vroooom ptssssh
It Wasnt Me!
Oil looks very emulsified, was it like that or is that just when it came apart?
Old Feb 10, 2010 | 09:29 PM
mattman1234
thanks for the replys chaps,think i'm going to take apart tomorrow
PaulinhoT
Oct 28, 2015 06:06 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
Blown Hell
Aug 5, 2015 07:22 AM
