Decent Caliper Paint
Old Aug 23, 2009 | 11:33 AM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Default Decent Caliper Paint
Hi,
looking to give my Golf's standard red calipers a new lick of paint. What caliper paint gives the best finish and is long lasting? Are the Halfords kits any good?
Also is it worth while spraying a coat of laquer over the paint once its dried?
Cheers,
Agar
Old Aug 23, 2009 | 02:14 PM
RichieST's Avatar
RichieST
The halfords stuff is quite good actually. Hammerite could be used, which is what I used on mine when I did them in silver, and that looks fine!
Old Aug 23, 2009 | 02:34 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
a good thick couple of coats of hammerite lasted on mine for a couple of years. i stripped the calipers down first before painting.
Old Aug 23, 2009 | 02:55 PM
RichieST's Avatar
RichieST
Reminds me of a story, a friend of mine a few years back put hammerite on the drums of an old cavalier. He coudn't be bothered to wait for it to dry, so drove off and it dried scarecrow stylee
Old Aug 23, 2009 | 03:00 PM
BM08's Avatar
BM08
Hammerite smooth from halfrauds will do you
Old Aug 23, 2009 | 03:22 PM
Graceland's Avatar
Graceland
Team HOTHOT!
I used Carplan Engine Laquor - £6 a tub from Charlie Browns or whatever they are called - never had a problem with this stuff, heat resistant upto 150 degrees celcius for prolonged temperatures, quite a lot higher for spiked temperatures
Old Aug 23, 2009 | 09:54 PM
godrikki's Avatar
godrikki
hammerite smooth as said above is more than up to the job done mines a year ago and its still fine
Old Aug 23, 2009 | 10:06 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
do not use the STP stuff, its fooking dog shit
i have always used the foliatech stuff and found that to be very good.
not tried anything else
Old Aug 23, 2009 | 10:47 PM
My rear calipers are done with smoothrite black
Old Aug 24, 2009 | 05:58 AM
foreigneRS's Avatar
foreigneRS
Testing the future
2nd that. comes as a 2 part epoxy that you mix up. thoroughly clean calipers first as well.
i have used hammerite in the past and found it ok, although couldn't say long term.
red calipers are gay btw. imo calipers should be black
Old Aug 24, 2009 | 05:29 PM
AGAR-COSWORTH
Redumbdancy
Lol, wasn't me who chose them to be red, VW did I don't mind them at all.
Anyway, is one pack of the Foliatech enough to do 4 calipers? It seems expensive compared to hammerite and smoothrite. However, ive used hammerite before and its flaked off after time
Old Aug 24, 2009 | 06:37 PM
foreigneRS's Avatar
foreigneRS
Testing the future
can't remember, i only wanted to do the front 4 pots on a cossie
Old Aug 24, 2009 | 06:48 PM
fuzzy's Avatar
fuzzy
if you check the small print on the backs of the tins hammerite has a higher temperature resistence than some of the specific high temerature paints.
prep them properly and it doesnt flake off.
Nov 1, 2015 06:53 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
muzzman1
Sep 30, 2015 08:59 PM
rsguy
44
Sep 29, 2015 03:29 PM
Sp3no
Sep 27, 2015 07:23 PM
