breather questions, outlet numbers ect
Old Dec 19, 2004 | 12:15 PM
Ginge !'s Avatar
Ginge !
just finding my feet
Default breather questions, outlet numbers ect
ok i been brave today and done some work on the cossie (well removed the battery )
now the breather i got is a ML developments jobby
its got 4 outlets, hooooge one on the bottom, smaller pipe off bottom and then 2 pipes at top
question is whats the small pipe at bottom ment to be connected too
curantly its leading onn the other side on the engine, is that right or not
also whats the inside of a breather mennt to be like as this one as a type of wall seperating the top from the bottom outlets]
it seems clean in there too , aint it ment to be dirty in there
also whats the thing one of the breather pipes are connected to that leads down where the plenum is
can ya tell ive removed it yet
im acutally gona polish this one aswell
Old Dec 19, 2004 | 12:20 PM
The DIVA's Avatar
The DIVA
Ginge......................the hooge one at the bottom vents to air,the small one at the bottom drains oil back into the sump via the fitting on the turbo side of the engine at low level,and the two at the top got to the rocker cover(you`ll have to put a fitting in)and the original breather......
Rob....
Old Dec 19, 2004 | 12:22 PM
Ginge !'s Avatar
Ginge !
thats exaclty how mines done
i took it out as igot told would be full of shite
its not, well its dirty outside
the small one on bottom is on the same side as the top parts, not on the vent to air side as theres that wall there
there was no pipe on the bottom of it though , gonan fit me blue ones now ( only had em since essex group show day
Old Dec 19, 2004 | 12:23 PM
The DIVA's Avatar
The DIVA
Got confused here mate .......is this already on your motor....
Old Dec 19, 2004 | 12:24 PM
The DIVA's Avatar
The DIVA
is the small one on the bottom returning to your sump and the big one got nothing connected
Old Dec 19, 2004 | 12:25 PM
Ginge !'s Avatar
Ginge !
yeah it was, just im wondering why its clean inside
was told they alll get full of crap
cheers for advice, was also making sure its routed correct way too
and it is
Old Dec 19, 2004 | 12:26 PM
The DIVA's Avatar
The DIVA
The wall by the way is a seperator to stop the oil mist blowing out to air,the oil then gathers in the bottom and drains back to the sump...
If its quite clean inside it means your motor is mint and not breathing too much
Ginge !'s Avatar
Ginge !
yeah big ones got no pipe at bottom, i got told im ment to have a pipe routing it under the car to avoid smells
Old Dec 19, 2004 | 12:27 PM
Ginge !'s Avatar
Ginge !
not from the noises it makes , thats why i was checking, might just be i got no oil in it
not breathing much is a good thing then , thats one off the check list
Old Dec 19, 2004 | 12:28 PM
The DIVA's Avatar
The DIVA
some people just put a little k+n type filter on the big one,or a pipe as you say..
Looks like your motors good anyway m8...
Old Dec 19, 2004 | 12:29 PM
The DIVA's Avatar
The DIVA
dont forget to check your oil daily.......mine used to do a sumpfull in aweekend if i drove it like a tw@t.....
Old Dec 19, 2004 | 12:31 PM
Ginge !'s Avatar
Ginge !
update, missus is shouting at the bad smell comming from the front room saying
"That better not be brought car parts in the house i can smell "
i cant smell it unless me nose is under it though
guess it must have been in use
Old Dec 19, 2004 | 12:33 PM
Ginge !'s Avatar
Ginge !
, thats what im thinking the knocking noise is, hence why im not starting the car
it looks fast, just dont start it and i dont wanna cry
theres no oil under car though but its deffo got various oil leaks, that then leads me to belive its comming from a gasket when under preasure
not sure if thats a good sign or not though
Old Dec 19, 2004 | 12:37 PM
The DIVA's Avatar
The DIVA
Top the oil up mate and see how she is.......
pmsl at your missus m8.........I got one just like that..
Old Dec 19, 2004 | 12:40 PM
Ginge !'s Avatar
Ginge !
well we moved and the garage aint close, her only rule was no car bits, i can get car memrobilia in the house, no oily stuff
ah well,
btw could i clean it in the dish washer ( when she pops to the shops obviously )
Old Dec 19, 2004 | 12:41 PM
The DIVA's Avatar
The DIVA
Cossies gotta be the only car in the world were the fooking bonnet hinges wear out before anything else.....
Old Dec 19, 2004 | 12:42 PM
The DIVA's Avatar
The DIVA
Don`t put it in the dishwasher m8 it`ll stink for weeks.....
She`ll fooking kill ya..
Ginge !'s Avatar
Ginge !
thats cause all the rest of it breaks
wait till i get the next car on the road , cossie will be gone
Ginge !'s Avatar
Ginge !
ill turn it off now then
Old Dec 19, 2004 | 12:44 PM
The DIVA's Avatar
The DIVA
Old Dec 19, 2004 | 12:50 PM
Ginge !'s Avatar
Ginge !
, all sorted
Ridgey
12
Nov 2, 2015 06:54 PM
155lee
Oct 27, 2015 04:55 AM
IainRS1700T
Sep 25, 2015 06:44 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
cossirob
Sep 3, 2015 09:17 PM
