news from pod
Old Aug 22, 2009 | 02:35 PM
blacky.'s Avatar
blacky.
Default news from pod
wenny rang earlyer
The transmition let go on the mk3 o the third run after getting a 10.6 & a 10.5
He said the third launch was the best he has done but lost drive as he changed to third
Old Aug 22, 2009 | 02:39 PM
andy130's Avatar
andy130
dam box, but great times whos all up there mate?
Old Aug 22, 2009 | 02:44 PM
Staffi's Avatar
Staffi
Gutted, BUT also fantastice times, well done Wenny......
Old Aug 22, 2009 | 02:46 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Bet the mainshaft has snapped? Shame as the times are awesome!
Old Aug 22, 2009 | 02:48 PM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
and how much did he pay for a "propper" box.....????
Old Aug 22, 2009 | 02:51 PM
RWD_cossie_wil
I would bet that it is the mainshaft that has snapped, not much you can do about that really but it is a cheap fix if it is that, just rob a mainshaft off any cossie compatable MT75 and its about an hour to swap them...
The big problem with any MT75 derived upgrade is that you are limited on the physical size of components by the original casings, hence why the mainshafts are the weak point now on the Bara/fixit/dome gearboxes.
Old Aug 22, 2009 | 02:53 PM
marco polo's Avatar
marco polo
by the sounds of it .......it could well be the mainshaft as 3rd gear would take it out no problem as thats where the flex on the mainshafts is at it's highest
he has give that box death it has lasted well
marco
Old Aug 22, 2009 | 02:55 PM
RWD_cossie_wil
marco
At least it's a dead easy fix Marco if it is the mainshaft ... Just shows how strong the gearkits are if it has snapped! Seen 2 like this now.
Old Aug 22, 2009 | 02:57 PM
marco polo's Avatar
marco polo
if it is the mainshaft..... .he would be better off in getting a mainshaft out of the mt75 2.0litre double overhead cam thoses gearboxes haven't seen abuse lol
marco
Old Aug 22, 2009 | 03:12 PM
pete mcrash
i've got a couple of spare "knackered" box's........i'm close to him aswell
Old Aug 22, 2009 | 04:00 PM
blacky.'s Avatar
blacky.
we will be swaping to the bara box that came out of it the start of the year. This one was the new one that i picked up last year from ford fairfair
So its not done a lot. The one thats going im is the one with lots of abuse under its beltbelt
It will be running at york next sunday
Old Aug 22, 2009 | 04:14 PM
Mike C's Avatar
Mike C
The Special One
Not nice to hear. Sounds like it was performing well again though prior to the failure.
Old Aug 22, 2009 | 04:24 PM
mad dog younge's Avatar
mad dog younge
blacky whos going to york with you
Old Aug 22, 2009 | 04:31 PM
marco polo's Avatar
marco polo
im sure bara will tell you whats wrong with it ............
had he got drive in any gears ? ............
if he hasn't then it's defo mainshaft which is standard part anyway
marco
Old Aug 22, 2009 | 04:57 PM
blacky.'s Avatar
blacky.
younge im not going next week as its michelles birthday
Most of the lads will be going though
Marco
He said he had a bit of drive to got off the strip then half way back it lost all drivedrive
He has checked all the shafts & props there all fine
Old Aug 22, 2009 | 08:24 PM
Spiky's Avatar
Spiky
maybe a diff then?
Old Aug 22, 2009 | 10:34 PM
andy escos's Avatar
andy escos
quick times shame about the box maybe time to get a reyland skyline box
Old Aug 22, 2009 | 11:22 PM
blacky.'s Avatar
blacky.
Originally Posted by Spiky
maybe a diff then?
When i spoke to him he said diff's shaft's & pros's all seam ok as dose the clutch action
Old Aug 22, 2009 | 11:29 PM
NEIL A's Avatar
NEIL A
Brilliant times just a shame about the box but atleast you have a spare so the car wont be out of action for long. I wonder what sort of times this car would run on a dog box, i know Kev dropped his times a bit when he went to an FFD.
Old Aug 22, 2009 | 11:33 PM
Fiddy's Avatar
Fiddy
Awesome times, bet he would have got lower times if it wasnt for the problems.
Old Aug 23, 2009 | 07:52 AM
Gutted to here that. I thought it was nearly bomb proof by now. It will soon be fixed and running again.
Old Aug 23, 2009 | 07:03 PM
WENNY's Avatar
WENNY
marco
now mate, was going to ring you yesterday to see what you thought but i think it is the main shaft aswell, put it into gear and you can still push car as if in nuetral, ill ring bara tomorrow and get it sent to him
is there any way of modding it, i got told to centre bore drill it and cyro dip it in nitrogeon for 24 hours
ashame aswell as i was after 10.2 or 10.3 this weekend and with the first 2 runs being 10.61 then 10.51, i still had the l/c to use and get into the groove after a few more runs
Minirotty
11
Sep 15, 2015 10:16 PM
21
Sep 14, 2015 06:38 PM
