External wastegate parts.. where to buy?
Has a large member
I need a 38mm sealing ring for the inlet part of the wastegate. anyone know where i could get this?
im stuck finding anywhere that sells bits on there own can only find full kits.
cheeRS
cheeRS
Has a large member
its an americian ebay no name jobbie. and it seems to have some inaccurately machined parts. the sealing ring provided didnt fit in the groove in the flange, was about a mil too big. so i machined off a mil and it fits in the groove fine now. but is still bloody blowing!
i think the rings not deep enough so wanted to try another one from a proper company that i know would have machined it properly, as far as im aware sealing rings are the same design/size on all applications (as long as its a 38mm one in my case)
it boosts fine in all gears but first. because first gears so short its not got enough time to build up more than 5 psi with the blowing
hope this helps mate
cheers paul
muz
Sep 30, 2015 08:29 AM
