Tuning the eec-iv ecu
Old Aug 21, 2009 | 10:52 AM
sailorbob's Avatar
sailorbob
Default Tuning the eec-iv ecu
For those that are interested in the capabilities of the eec-iv ecu the following zip file contains a GHAJ0 strategy definition file (aka 'def') and the code from a small turbo Escort Cosworth 'ANTI' ecu (aka 'bin' file). You need to use the 'Binary Editor' s/w (available here) to use the definition.
You can only view the various scalars, functions and tables that the ecu has but it gives an idea of the complexity and power of the eec-iv management.
For BE2010: GHAJ0
For BE2012: GHAJ0
Enjoy
PS There is the odd error in the def which is to be expected when reverse engineering an ecu.
Old Apr 6, 2010 | 10:48 AM
mhs's Avatar
mhs
[Quote = sailorbob; 4348350] olanlar eec-iv ECU yeteneklerini aşağıdaki zip dosyasını küçük turbo Escort Cosworth 'ANTİ' ECU bir GHAJ0 strateji tanım dosyası (aka 'def') ve kod içeren ilgilenen (aka 'bin' dosyası). Sen Binary Editor 's / w (mevcut' kullanmanız gerekir burada) Tanımını kullanmak için.
Sadece çeşitli skalerler, işlevleri ve tablolar ECU var görebilirsiniz ama karmaşıklığı ve AET-iv yönetim gücü hakkında bir fikir verir.
GHAJ0
Zevk almak
PS var ne zaman ters mühendislik bir ECU beklenebilir def içinde tek hatadır.[/ Quote]
link please
Old Apr 6, 2010 | 11:42 AM
sailorbob's Avatar
sailorbob
The two links are in the first post.
Old Sep 23, 2012 | 10:09 PM
bryndisi's Avatar
bryndisi
EsCos SORN :(
Hi sailorbob,
Is there an updated version of these def and bin files? I'm messing around on Binary Editor 2012 and it reports them out of date!
Thanks
Old Sep 24, 2012 | 09:17 AM
sailorbob's Avatar
sailorbob
The bin file is independent of the BE version but the definition is for BE2010 only. I have no plans to upgrade the definition in the immediate future.
Old Feb 18, 2013 | 06:01 AM
jsa's Avatar
jsa
Hello Sailorbob,
The link seems broken for ghaj0, would it be possible to get a copy please ?
Old Feb 18, 2013 | 02:35 PM
sailorbob's Avatar
sailorbob
New links created in the original post.
Old Feb 18, 2013 | 06:24 PM
jsa's Avatar
jsa
Hello Sailorbob,
Thank you.
Are you doing anything more with GHAJ0 or have you given up on it ?
Moates talk about needing a patch code to do logging, does GHAJ0 have the patch code ?
http://support.moates.net/ford-guide...ates-hardware/
Old Feb 19, 2013 | 06:53 AM
sailorbob's Avatar
sailorbob
I'm not doing anything more with it. There isn't much else to be done, pretty much every parameter is in there along with the patch code.
Old Feb 19, 2013 | 06:56 AM
jsa's Avatar
jsa
Old Feb 19, 2013 | 07:05 AM
jsa's Avatar
jsa
Hello Sailorbob,
OK thanks.
Old Feb 19, 2013 | 07:23 AM
jsa's Avatar
jsa
Thumbs up
Old Feb 19, 2013 | 09:49 AM
sailorbob's Avatar
sailorbob
It works OK for me but I've put up a an altered version.
Old Feb 19, 2013 | 06:26 PM
jsa's Avatar
jsa
Thumbs up
Luvyerwork, Altered GHAJ0 for 2012 version loads up for me without the previous errors.
Old May 22, 2013 | 09:55 AM
jsa's Avatar
jsa
Hello Sailor Bob,
Been prodding the DLC/DCL RS485 data port on my COSY EEC-IV that has a GGR chip.
With GGR chip it reports CARD, without GGR chip it reports COSY, what do you make of this ?
Also both report different 6 digit strategy codes GHAJ0xx, the last two characters are different ?
Old May 22, 2013 | 10:14 AM
sailorbob's Avatar
sailorbob
The GGR chip is based upon the CARD binary file This is basically the same as COSY but it fixes a bug in the original code that caused improper initialisation of ram variables at power up and it alters some wastegate related parameters. There's also an ANTI bin file out there that just fixes the bug.
The last two digits in appended to the strategy name indicate the calibration.
Old May 22, 2013 | 10:42 AM
jsa's Avatar
jsa
Hello Sailorbob,
Thanks.
Elsewhere you mention your anti strategy and definition can be used in place of COSY, does it work in both directions for ANTI and CARD definitions under GHAJ0 ?
At the moment it spits out MAP and HEGO faults. From your explanation, seems catch code is not a factor.
Old May 22, 2013 | 12:42 PM
sailorbob's Avatar
sailorbob
Any calibration file from the same strategy can be used with the same definition for that strategy.
Old May 22, 2013 | 08:50 PM
jsa's Avatar
jsa
ok thanks.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
SMILER258
Sep 28, 2015 09:04 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
