Breaking clubman group A all parts for sale ! - UPDATED 12/02 !
It is with sadness that I have to sell my car and all parts I bought to build it as a clubman group A car. I have been confirmed as a high-school student and my parents cannot pay for everything, as it cost a lot of money to do that school (10'000euros per year and its 3 years long).
So all the money I will get from these parts will be for my 3 high-school years and all what is around it (flat, food, ...). So please reasonable offers, as the most I can get out of these parts, the less I will have to lend to the bank.
Pictures uppon request, and offers welcome by email on the address blow this message !
BODY
- Carbon/kevlar bonnet with small holes for lamp pod but can be easly "repaired" to put it back std --- 750euros
- Carbon lamp pod complete with lights, all NEW --- SOLD !
- X-sport racing carbon/kevlar boot, NEW --- 250euros
- Carbon rear view group A mirrors (uniques pieces), NEW --- 250euros
- Morettes for LHD car, unpainted, as new --- SOLD !
- Front lid which goes under the lights without holes for washers (very rare) ideal for Morettes, NEW --- 75euros
TRANSMISSION
- MT75 DOME semi-straight cut gearbox fully revised --- 2000euros
- Front DOME diff with strenghtning plate --- 550euros
- Rear Quaife 7.5" diff 4.44 ratio, NEW --- SOLD !
- 4.44 kit for transfert box including all new bearings --- SOLD !
- Center VC 60Nm, NEW from Bara --- 350euros
- Rear 4x4 cosworth driveshafts, NEW --- 230euros
- Alcon 6 paddle "race" clutch kit with renforced cover and the small clutch "lock", as new less than 1000miles --- 350euros
- Std MT75 gearbox with transfert box --- SOLD !
STEERING
- LHD genuine group A sapphire steering rack (ultra-rare !) --- SOLD !
- Std LHD steering rack complete --- SOLD !
BRAKES
- Front group A AP Racing 4 pots 315mm discs with pads gravel specs --- SOLD !
SUSPENSION
- Front jumbo 50mm Bilstein group A coilovers which fits std hubs, watercooled bodies, gravel specs, NEW --- 850euros
- Suhe Motorsport compression strut kit which keep the use of the front antiroll bar, NEW --- SOLD !
- Front group A strut brace black, as new --- 150euros
- Rear group A early gravel specs rear beam with DOME modded arms, fully re-painted --- 1000euros
- Rear strut brace mat white diamond white paint, NEW --- 70euros
ENGINE
- L8 ECU with MSD chip for T4, RS500 ic, Siemens 55lb injectors, has ALL msd features : ALS, launch control, wasted spark and closed loop. Produced 430bhp --- SOLD !
- Wasted spark kit including MSD loom, twin ign amp with MSD bracket, coilpack, new Motorsport leads, new Denso Iridium IK27 sparks plugs, as new lambda sensor --- SOLD !
- T35 Mountune group A turbo with maram 247 shaft, 0.63 exhaust housing, wastegate, Mountune air-restrictor, no cracks, no play in shaft, perfect condition --- 1200euros
- Group A Air/air injectors --- 300euros
- Complete Bailey breather system with aeroquip and goodridge hoses --- SOLD !
- 16x double valve springs (no head mods needed), NEW --- 200euros
- WRC head gasket, NEW --- 200euros
- Mocal water or oil 19 row cooler, NEW --- 150euros
- Aquamist water injection kit with pump, few pipes and a valve, as new --- SOLD !
- 16x hydraulic lifters, NEW --- SOLD !
- 3 bars MAP --- 55euros
- Bosch group A 044 fuel pump, NEW --- 120euros
- Mountune proper throttle body for antilag --- 250euros
- Mountune proper camshafts pulleys 165euros
- Mountune proper ISCV for antilag --- 150euros
- Modded throttle body for antilag --- 150euros
- Siemens 55lb injectors, NEW --- 200euros
- Std escort cosworth T35 airbox --- SOLD !
- Carbon top part of sapphire cosworth 4wd airbox --- 50euros
- HP spring and cap kit for 4wd oil pump, NEW --- SOLD !
- Used 4wd oil pump, in good state --- 75euros
- Roose Motorsport black water hoses complete kit for sapphire cosworth 4wd, NEW --- 250euros
- Roose Motorsport blue air hoses complete kit without T-dump valve for escort cosworth t35, NEW --- SOLD !
- Escos group A chargecooler with water/methanol injector, fixations removed to ideal for sapphire upgrade --- 100euros
- Inlet manifold modded to fit Mountune head, with grey injectors, aeroquip hoses, fuel pressure regulator --- 350euros
- Fuel injectors ramp modded to be used with aeroquip hoses, and extra place to put a fuel pressure sender --- 50euros
MISC
- Ford Motorsport Sparco Rev carbon racing seat with Delecour's name on top, seat he used in his works 1994 group A escort, ultra-rare piece of history --- offers
- Pectel monitor with extra inputs for fuel pressure oil pressure and EGT, datalog, pod modded to be fitted onto the steering wheel, can be put back as original, very rare ! --- offers
- K-type EGT sensor, inconel, with extra lead extention and fittings, all NEW --- SOLD !
- Alternator group A 150amp kit, NEW --- 150euros
- Engine sump and gearbox alu group A guard, very strong --- SOLD !
- Engine group A support guard, blue anodised --- SOLD !
- Front group A engine support brackets and guard tarmac specs --- SOLD !
- 50mm boost pressure gauge, -1 to 2.5bars, NEW --- 65euros
IF YOU'RE INTERESTED BY THE PARTS, PLEASE EMAIL ME AT : webmaster@mycosworth.com
No MPs !
All prices can be discussed but not much please, because again, I need all the money to pay the school. Usually I do offer shipping everywhere in Europe, and sometimes it cost a lot, so bargin for you !
BODY
TRANSMISSION
STEERING
BRAKES
SUSPENSION
ENGINE
MISC
No MPs !
Matt,
there was a bloke going on a few days ago about the brake coolers,did he contact you about them ??
sorry to here your selling up,shame you can't get a part time job and keep your car.
cheeRS Karl
cheeRS Karl
one other thing Matt,
if Francois did indeed sit in that seat in 1994 its a very very rare piece of ford motorsport boreham history,francois smashed his feet in a accident in his mates ferrari f40 in 1994 thus in what many ford fans consider to be the real reason ford was robbed of the 1994 wrc championship . he didn't do many rallys at all in 94,thats why it would be rare and tbh i would offer it to francois first and see if he fancy's it.
cheeRS Karl
cheeRS Karl
Yes that's really a big shame for me because I already put so much work in the car, went few times to UK to pick up parts and now have to sell everything. But again, school is more important, and in 3 years if I can get a proper job, I'll be able to go back to the Cosworth world !
Karl, that would be a great idea, I will contact François' co-driver of now which is a female co-driver btw, as I got it touch with her few years ago ! Indeed the date stamped on the Sparco sticker behind the seat says 28/02/1994 so that could be !
And about the brake cooling ducts, I am still waiting for them, like I'm waiting for Tim Finch's parts to come (more than 1 year).
I should get them soon hopefully, then will sell them to who wants to have some brake coolers, so he can make more from them.
Guys, please send me an email to the address I've put, I won't answer prices or things in this thread or by MPs as its more secure by emails. Drop me one so I can send you pictures too !
ANNE CHANTAL PAUWELLS is her name and she used to be francois's girl friend and rally co driver in the sierra's,not 100 percent she sat in the escorts as that was dan grataloup.
best of luck but it has to be said your Mad Matt
Haha thank you Karl
Well I just sent an email to Melanie Romfort which is François' actual co-driver so I'll see what comes up, but thank you for the idea Karl, I don't know if François is "nostalgic" but anyway he has a chance to put his hands on one of HIS seat ! :P
Btw if anyone has got 100'000euros to spend, I can give the email address of someone who is rebuilding (he probably has finished it now) an ex-Biasion Sierra Cosworth works group A car with ALL proper 909 parts (including FFD 7 speed gearbox, 9" rear diff, ...) all new parts of fully revised, amazing.
Wish I had the money !
I have been very busy in the past few months so I had to let on a side the parts, now I have got bit more time to look after this, so I updated the list ! Feel free to ask for pictures if you are REALLY interested !
23
Sep 12, 2015 12:56 PM
FlashRS
13
Aug 31, 2015 06:02 PM
155lee
Aug 14, 2015 11:21 AM
