Idle problem
Old Aug 19, 2009 | 09:54 PM
gtcoupejc's Avatar
gtcoupejc
Default Idle problem
1990 Sierra 2.0 GLS, when started the it usually doesnt idle correctly, it dips down below 500rpm then goes back up to over 1000rpm, it goes up and down for around 20 to 30 seconds then just dies out altogether but always starts no problem...........any ideas on what the problem could be anyone??
thanks in advance
Old Aug 19, 2009 | 10:24 PM
gtcoupejc's Avatar
gtcoupejc
NONE OF THE SIMILAR THREADS ARE SIMILAR TO MY PROBLEM IF YOU KNOW WHAT I MEAN
ANYONE ANY IDEA??? seems like a sensor or something
Old Aug 21, 2009 | 08:02 AM
I assume this is a twinky engine ?
I would be looking at mixture related things, is it fine when hot ?, try cleaning the iscv.
Old Aug 21, 2009 | 08:43 AM
gtcoupejc's Avatar
gtcoupejc
its 2.0l twincam engine, no when its hot it does the same thing.....
Old Aug 22, 2009 | 06:54 PM
I'd be cleaning the valve, and looking for an air leak, on induction side.
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
