electric power steering
Old Dec 18, 2004 | 08:17 PM
AJ Escos's Avatar
AJ Escos
Default electric power steering
was doin' some work on my m8's motor today and wondered if any one had fitted an electirc steering pump on an escos and if so is any info available
Old Dec 18, 2004 | 08:58 PM
markk's Avatar
markk
im just fitting one to my car
Old Dec 18, 2004 | 09:41 PM
AJ Escos's Avatar
AJ Escos
how did you go about finding out what pump to use, ie:what pressures they run at compared to an escos mechanical pump, cos i cant find anything
Old Dec 18, 2004 | 09:45 PM
Sean Bicknell's Avatar
Sean Bicknell
Martin Hadland ran electric power steering on his car for about a year before the crash. He would be a good man to ask.
Old Dec 18, 2004 | 10:57 PM
markk's Avatar
markk
ive got two electric pas pumps and there fookin great !!
Old Dec 18, 2004 | 11:04 PM
AJ Escos's Avatar
AJ Escos
thats good although not much help to me unfortunately
Old Dec 18, 2004 | 11:08 PM
markk's Avatar
markk
i fi remeber tomorrow , ill halp you out alittle bit , my pumps are off diff models , remind me , cant be arsed at the mo , ill pm you some details
Old Dec 18, 2004 | 11:14 PM
AJ Escos's Avatar
AJ Escos
cheers m8 that would be great
Old Dec 19, 2004 | 07:09 PM
nicksaph's Avatar
nicksaph
hello mate
the citroen ax uses an electric pas pump,
could that be suitable for the conversion?
Old Dec 20, 2004 | 12:18 AM
AJ Escos's Avatar
AJ Escos
will check that out m8 thanks
AJ Escos's Avatar
AJ Escos
will check that outy m8 thanks
Old Dec 20, 2004 | 05:06 AM
jayRS's Avatar
jayRS
i take it this could be fitted to a fiesta if i had all the bits? i knowm some came with power steering but a electric pump would be a lot easier
Old Dec 20, 2004 | 06:29 AM
gazcos's Avatar
gazcos
I think MGFs have electric PAS but you will need a suitable speed sensor to make it work..........i think
Old Dec 20, 2004 | 06:44 AM
foreigneRS's Avatar
foreigneRS
Testing the future
most cars come with electric pas pumps these days. probably most common (and therefore cheapest and easiest to get hold of) are vauxhall astra, corsa etc.
the only difficulty i see is mating them to a ford steering column and making some hoses up to take the pressure. and mounting them so that they don't vibrate the whole car to pieces.
Old Dec 20, 2004 | 06:26 PM
nicksaph's Avatar
nicksaph
the citroen one is a stand alone unit fitted on the NSF chassis rail, it has power to it as soon as the engine is started' then all you need is to connect up the pipes from the existing pas rack
sorted!!!
Old Dec 20, 2004 | 06:41 PM
AJ Escos's Avatar
AJ Escos
new corsa's have an electirc motor on the column.
Old Dec 20, 2004 | 08:03 PM
markk's Avatar
markk
yes
Old Dec 20, 2004 | 10:25 PM
900ss's Avatar
900ss
RWD Racer
You can use a remote elec hyd pump like a saxo or 106/307 say, or a power column n elec mota like the late corsa n punto etc etc
Old Dec 20, 2004 | 10:30 PM
AJ Escos's Avatar
AJ Escos
looking more into remote pump really as i think the motor way would be to much hassle.
Old Dec 20, 2004 | 10:40 PM
900ss's Avatar
900ss
RWD Racer
Use one from a Peugeot; Citroen in that case? Or even some of the late Ashtrays are also remote. A trip round a breakers would prob give you a few ideas.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
stevecfrst1
Sep 30, 2015 05:18 AM
