fuse box
Old Dec 18, 2004 | 02:02 PM
townie9371's Avatar
townie9371
Default fuse box
how do you remove the fuse box on a s2 rst,i dont need the cable out just want to take box off bodywork.
Old Dec 18, 2004 | 02:38 PM
escort1989uk's Avatar
escort1989uk
pull on the cables it will pull the fuse board out revealling three cross head screws undo those and there you go bobs your uncle
Old Dec 18, 2004 | 02:40 PM
townie9371's Avatar
townie9371
cheers mate
Old Dec 18, 2004 | 02:41 PM
escort1989uk
well i shocked it has taken people this long to help you out. sorry about peeps on here the get less helpful every day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
Old Dec 18, 2004 | 04:55 PM
Damo V's Avatar
Damo V
you cant take "just" the fuse board or case out ... have to pull the whole loom out of car throufgh the hole once you have undone the 3 above mentions self - tappers
Old Dec 18, 2004 | 06:09 PM
townie9371's Avatar
townie9371
how do you pull the whole loom out?sounds complicated 2 me
how do you get at it etc,does it unplg somewhere
Old Dec 18, 2004 | 06:14 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Its a long job to fully remove the loom as it is attached to the fuse board and cant be removed very easy.
If you do want to remove it you will need to take the dashboard out!
HTH
Damo V's Avatar
Damo V
yeah it unplugs... off the back of the dash, switches, door loom at A pillars, rear lights, fuel tank ... etc.... aint simple im afraid
Old Dec 18, 2004 | 06:19 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
if your just lifting it up slightly,you will be ok, look inside the car, above the pedals, you will see the loom, i just made sure the cable ties holding everything tight, were cut, it then gave me a chance to lift it up, a little bit, just dont pull the wires about too much, or you might have problems later, if you look at the box, without the cover on it, get a thin screwdriver, look for a hole, "cut out " at the front edge, nearest you, on bit with the fuses in, then "pop" it out of the casing of the fusebox, revealing the screws, , as its been mentioned, it is easy, once you have done it once, good luck,
dave
Old Dec 18, 2004 | 06:21 PM
Deerhunter's Avatar
Deerhunter
formerly uyo1972
cheers damo, i didnt know it was like that to remove it completely ,
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
