Mondeo 1.8TD normal temp?
Old Aug 17, 2009 | 08:48 AM
Matt-G's Avatar
Matt-G
Default Mondeo 1.8TD normal temp?
Hi guys,
So today the Ramshackle Mondeo is having it's new alternator and all the belts changed todat.
https://passionford.com/forum/restor...rally-car.html
I noted driving it today (it's only just been taxed so have only just been able to start putting some miles on) that it does seem to run pretty cool, right at the bottom of the "normal" of the gauge. I left it running to ensure the fan kicked in which it does at around the beginning of the o in normal so still below the mid point of the gauge.
Does this sound right? I'm guessing it could be the gauge misreading or a dodgy sender or perhaps the 'stat is goosed?? Are any of these common faults on this engine or am I just worrying about nothing?
Thanks in advance,
Matt
Old Aug 17, 2009 | 10:50 AM
Is the heater any good, if it is then it is fine and the stat is doing it's job, I wouldn't worry about accuracy of the gauge, it's a ford.
Old Aug 17, 2009 | 11:07 AM
Matt-G's Avatar
Matt-G
Thanks Tabetha that's good to hear... Yes, heater is warm (not roasting but warm) and top and bottom hoses seem to get evenly warm too so hopefully all is well
Old Aug 17, 2009 | 07:26 PM
forevaford's Avatar
forevaford
mk1 an early 2s mondys td seem to run a low temp i always put it down to inaccurate guage.
Old Aug 18, 2009 | 10:48 AM
See if it gets better when you change the stat, as heater should be roasting really on a mondy, they're excellent, warm up time will give a clue as to whether it is lazy or not, try and use a WAHLE one when replacing.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Mark RS
Oct 12, 2015 06:01 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
