Sierra fuel guage problem
Old Aug 16, 2009 | 05:35 PM
gtcoupejc's Avatar
gtcoupejc
Default Sierra fuel guage problem
I have a 1990 ford sierra GLS, 2.0L,
the lastg day the fuel hand dropped way below the minimum level, and then later returned to half full where it should have been, but the needle has since dropped to the very bottom again.
i checked fuses incase it might have been that but no sign. anyone any idea or is there any common faults with these, maybe a wire loose or something somewhere?????????
any help would be great!
Thanks in advance
Old Aug 16, 2009 | 05:39 PM
m4tt274's Avatar
m4tt274
its a common fault to have fuel gauge problems. cossies arent usually driven enough for them to go wrong but nearly every P100 has a broken fuel guage. its usually bad connections.
Old Aug 16, 2009 | 05:41 PM
gtcoupejc's Avatar
gtcoupejc
bad connections at the tank or behind the dash?? just so i know before i start pulling things apart
Old Aug 16, 2009 | 05:43 PM
m4tt274's Avatar
m4tt274
either m8, on my old P100 it was the connection on the sender near the tank. it was all green'd up
Old Aug 16, 2009 | 05:56 PM
gtcoupejc's Avatar
gtcoupejc
no problem thanks, ill check them out tomorrow
Old Aug 16, 2009 | 07:36 PM
Usually is the connections near the tank/sender.
Old Aug 16, 2009 | 08:57 PM
gtcoupejc's Avatar
gtcoupejc
thanks, ill drop the tank and get a look someday this week
jc1989rs
Aug 30, 2015 06:32 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
