volvo rear discs
Sorry its non ford fellas, anyone know how to get the rear discs off on a volvo s60?
There is a handrake mechanism inside the back of the disc and i cant see how it all comes loose. The caliper is off, disc is loose but it will not come off the hub.
Any ideas please?
Many thanks
Muffster.
Any ideas please?
Many thanks
Muffster.
Any ideas please?
Many thanks
Muffster.
Any ideas please?
Many thanks
Muffster.
If you look inside the car next to the handbrake there is a small cover you pull off you will find a 10mm nut which is the adjuster nut it will need to be right to the top otherwise they will not come off,if you want my advise put new handbrake shoes on now as they are bound to fall apart when you take them off
i hope this helps
Russ
Hi Muffster
i hope this helps
Russ
i hope this helps
Russ
All sorted and you were right about the handbrake shoes.
Many thanks
Muffster
155lee
Sep 6, 2016 11:10 AM
