arp rod bolts..re-use????
Old Aug 14, 2009 | 10:49 PM
forevaford's Avatar
forevaford
Default arp rod bolts..re-use????
cosworth yb 400 + bhp
im getting the engine apart, can i re use/ re torque these arp big end bolts or is it recomended to replace?
thank you
Old Aug 15, 2009 | 09:00 AM
2001ode's Avatar
2001ode
thank you
IMO replace, replace !!!!!!
Have you seen an engine with end bolt broken ??? Every parts are died.
Claude.
Old Aug 15, 2009 | 10:06 AM
They only really need replacing for peace of mind or if they are stretch bolts.
I would for the cost replace as they have quite a hard life.
Old Aug 15, 2009 | 01:11 PM
2001ode's Avatar
2001ode
If it was a stock engine, yes, but with 400 hp, IMO, I replace.
The balance is : total cost engine vs 8 conrod bolt cost.
Claude
Old Aug 16, 2009 | 12:04 AM
forevaford's Avatar
forevaford
yep, i under stand, cosie cranks block heads aint so cheap!!
advice taken
thanks people
little bram
Sep 27, 2015 07:45 AM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
little bram
Sep 10, 2015 10:45 PM
