what guages
Old Dec 18, 2004 | 10:16 AM
escort1989uk's Avatar
escort1989uk
Default what guages
ordering from nomad for my series 2
heater vent gauge holder(has 3 holes)
1,so thought air/flow meter
2,boost
3,?
ain't got a clue what to get so your ideas are welcome
Old Dec 18, 2004 | 10:37 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I assume you mean Air/Fuel Ratio??
Oil Pressure is probably the next easiest one to connect.
Old Dec 18, 2004 | 10:41 AM
Jasesapphy's Avatar
Jasesapphy
Volts is even easier
Old Dec 18, 2004 | 10:46 AM
escort1989uk
why would i want volts thanks C&B
Old Dec 18, 2004 | 01:25 PM
tiny's Avatar
tiny
So u would no that the alternater is charging the battery.
What about water temp?
Old Dec 18, 2004 | 02:05 PM
Ginge !'s Avatar
Ginge !
just finding my feet
i would avoid a afr gauge unless ya get a proper jobby, the cheap ones aint acurate, point of gauges is for em to tell ya whats going on
if ya got a big front mounted i/c the water temp, oil presure and boost
Old Dec 18, 2004 | 02:34 PM
escort1989uk
got it from nomad take a look and tell me if it is poo. www.nomadracing.com
oh ginge get of your band wagon
Old Dec 18, 2004 | 02:38 PM
Ginge !'s Avatar
Ginge !
if ya think im talking shite then
i know a memeber of thi board bought a decent afr gauge for 300 quid thats wide band and when his car was being set up it wasnt reading correctly
if ya think the afr is all cool and its not theres no point having a gauge, all its gona do is give ya a false sence of security
same with front mounted coolers , ya wanna know ya water temp otherwise listening to the ford gauge if thats wrong then good by head gasket
but then each to there own
Old Dec 18, 2004 | 04:12 PM
AJC's Avatar
AJC
if you get an oil pressure guage dont get a ancillary one cause the
sods decide to leak into your car causing oil to go every where,
thats from experience with 3 different ones, get an electrical one
Old Dec 18, 2004 | 04:15 PM
Strippedfez's Avatar
Strippedfez
Get a oil temp one, easy to wire in and very helpful!!
Old Dec 18, 2004 | 04:19 PM
james_birch's Avatar
james_birch
i would go for sumit that will help keep ya engine alive! oil temp/pressure! waster temp...sumit like that
Old Dec 18, 2004 | 04:20 PM
Ginge !'s Avatar
Ginge !
why is oil temp important on a road car
Old Dec 18, 2004 | 04:23 PM
james_birch
cus once ya oil is up to temp you can then thrash ya car safe that you know your engine is at safe temp?! perhaps?!
Old Dec 18, 2004 | 04:24 PM
Ginge !'s Avatar
Ginge !
mmmmmm good point that
think its not the most important though
Old Dec 18, 2004 | 04:36 PM
Ian M's Avatar
Ian M
b19bal,
how do you listen to a gauge ????
Old Dec 18, 2004 | 05:40 PM
cossiemen's Avatar
cossiemen
Whassup
by using a headphone
Old Dec 18, 2004 | 06:11 PM
Ginge !'s Avatar
Ginge !
ya know what u mean, ford gauges tell ya infomation but dont actually say "hi mate, beter slow down, getting abit hot, gonna have to melt a piston soon to get relief "
so yeah to do listen to what ya gauges tell ya
oh and what about alarms in gauges
15
Oct 7, 2015 03:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Derek Burleigh
Sep 16, 2015 06:27 PM
ldack
Oct 27, 2004 07:06 PM
adamS2RST
Jun 22, 2004 09:42 PM
