Zetec Head Gasket Question
Old Aug 12, 2009 | 10:05 PM
Smiler's Avatar
Smiler
Default Zetec Head Gasket Question
Hello folks,
I am finally getting round to re-uniting the zetecs head with the block in my much neglected Escort but want something clarifying first. There might be a problem with the head gasket.
Pictured below is the head gasket sat on the block in all its pre-clamped glory.
Now the next two pics show a closer view of cylinders 1 & 2 and 3 & 4. Take a look at the passageways in the head gasket for the water jacket. They are much smaller on cylinders 1&2 than the jacket aperture itself but on cylinders 3 & 4 they are tiny, almost like pilot holes.
Now is this normal or do I have a faulty head gasket? I was considering cutting the material away to completely open up the water channels on all cylinders. Does this sound wise or is the restriction on those cylinders there for a reason?
Cheers for the help,
Smiler.
Old Aug 13, 2009 | 07:53 AM
It's there for a reason, the head gasket is fine, don't go chopping stuff about.
Old Aug 13, 2009 | 04:15 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
the head gasket is designed to help water flow more evenly across the engine and reduce heatspots.
perfectly normal.
Old Aug 13, 2009 | 06:39 PM
Smiler's Avatar
Smiler
Makes sense to me, they just seemed a bit too small. It is now half fitted. I say only half fitted as I have since discovered that I've misplaced the mondeo haynes manual for the engine and so don't have the torque figures. oh well, best start a new thread then!
JK12
33
Apr 26, 2021 12:09 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
hopper350
Sep 4, 2015 12:53 AM
