2wd saff questions
Old Aug 12, 2009 | 07:10 PM
2wdsaff's Avatar
2wdsaff
Default 2wd saff questions
Hi folks,
just brought a 2wd saphire cosworth thats been sitting up for around 5 years, only time its been run is to get it on a trailer and off again to shift it about. never been driven anywhere etc. I am picking it up next saturday, but im wanting to get the fuelling checked before i take it home to shetland as we dont have a rolling road set up up here, thing is will it damage the car after it sitting so long to just let a tuner roast it on a RR or would it be best to wait till its done a few miles before i get it done? any advice would be greatly appreciatted
thanks
Old Aug 12, 2009 | 07:19 PM
andy130's Avatar
andy130
needs oil changed new petrol,plugs,filters all round , all new belts
Old Aug 12, 2009 | 07:26 PM
2wdsaff's Avatar
2wdsaff
hmm your damn rite! been too busy wondering about the fueling that i didnt even think about the essentials first!!!! what a fool! cheers andy
Old Aug 12, 2009 | 08:02 PM
As said defo a COMPLETE service from top to bottom first, inc fuel filter change, pump voltage check, or better rewire, along with fan rewire, using gently will do no harm, to loosen up while you service it, don't forget belt/tensioner change, and drain old fuel, out.
Old Aug 12, 2009 | 08:05 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Cambelt, cambelt, cambelt.
Old Aug 12, 2009 | 08:38 PM
james kiely's Avatar
james kiely
maybe it would be worth flushing the cooling system to
cheers james
Old Aug 14, 2009 | 05:24 AM
2wdsaff's Avatar
2wdsaff
yes i was thinking all of the above, would it be best to flush through fresh brake fluid aswell and maybe change the diff/gearbox oil while im at it?
Old Aug 14, 2009 | 11:48 AM
doRSet lee b's Avatar
doRSet lee b
of course it wouldnt hurt, if you got the time then do it.
Old Aug 14, 2009 | 10:12 PM
2wdsaff's Avatar
2wdsaff
also whats the main differences between the 2wd saff's and 4wd ones? my saff is a 2wd in a 4wd shell but im not all sure yet what parts are 2wd and whats 4?!
Old Aug 15, 2009 | 10:14 AM
Lots of minor detail differences, but mostly just the obvious mechanical ones, the bulkhead is thicker material on the 4wd shell, so I'm led to believe, never measured myself, front cross member is totally different, 200 block(in 4wd) is much stronger/stiffer, cooling system different.
Music & Car Audio Chat
Sep 3, 2017 01:24 PM
155lee
Oct 27, 2015 04:55 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
dojj
28
Sep 11, 2015 10:00 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
