Difference between ofab and ofac?
Hi im looking to build 2.1 zvh but dont know which one to buy?Might sound like a silly question is one code for ecu and other loom any help would be appreciated!
ofab is easier to upgrade because the map sensor can be changed easily to run more other than that there isn't much difference.
i was advised to go with ofab when i changed mine and have had no problem with it at all- i have heard of some teething problems with ofac on the other hand.
If your gonna run a 2.1 zvh though i agree with karlos you need a live mappable system or you'll never get the best out of it
ab uses an analogue map sensor and can be swapped for a 3 bar from a cossie. Ac uses a digital sensor that cannot be changed as there is no direct replacement, but it is a 2.5 bar sensor anyway.
wowk
Mar 30, 2021 07:49 PM
SMILER258
Sep 28, 2015 09:04 AM
