aeroquip adapters dimensions for 200 YB block
Old Aug 12, 2009 | 03:57 PM
ital_cossie's Avatar
ital_cossie
Default aeroquip adapters dimensions for 200 YB block
hello,
i would like to inform me the dimensions of the two adapters for the oil breather, one for the exhaust side of the 200 cosworth YB block:
and the other one under the inlet manifold:
waiting your info
thanks
Old Sep 2, 2009 | 08:40 AM
ital_cossie
BUMP!!!
any help!!!???
Old Sep 2, 2009 | 10:19 AM
jon@work's Avatar
jon@work
The block in the pic above has been modified on the inlet side. As standard it is not threaded, but a plain hole approx 20mm diameter.
Under the turbo, the thread is 3/8 NPT.
Old Dec 9, 2009 | 12:05 PM
ital_cossie
so an adapter M20 to - 12 AN will be fine?
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
