Wasted spark question
To get my Rev Counter working along side the RPM input on my AVC-R I have had to run a wire direct from my Rev Counter to both coil pack earths (bridging them), as far as I can tell this will mean all 4 plugs spark all of the time.
Normally it would only spark 2 wasting 1, but now it will be sparking 4 and wasting 3.
I just wanted to know if for any reason this would be a problem for the engine aside from wearing out the coils and plugs quicker which is negligible? Is there a chance it could ignite the gasses on the intake stroke or must they be compressed before thats possible?
It runs fine but any input is as always, welcome!
it was a while ago aron , but gaz showed me how to to it, if i remember it was the centre pin and the two outers are earths and it switches between the two if you know what i mean
next time ur around ill show u my clocks and see if you remember! ive asked this question on here loads someone said something about an amp?
Yeah I can Carl but it's running my AVC-R, if I try and use it with my rev counter as well the AVC-R shows about 6000rpm at idle! lol!
Just tried the centre pin to the rev counter and that doesnt do anything at all!
But no need to worry now as I have this handy diagram to show me what I need to do!
bit late here, but no you can't run the two wires from the coil pack, you muct use the setup like in the diagram you've found.
the 1N4004 diodes can be bought from Maplins for a few pennies, the zener one isn't one they stock, you'll have to find a substitute one that they do sell, check on their online shop to identify one they do sell.
i bought what i needed for around 69p, lost the parts now so have to do the same again.
The finished item..........
Works ok.... but the rev counter hangs and fall back jerkily rather than smooth like it did when I had it running off the coil pack with out the diodes inline
The ECU will not run the Tacho direct, it's a low voltage output.
I could try the AVC-R to the coil pack although it will need to go through the above Diode setup too.
Actually, thinking about it - run the avcr straight of ONE of the coil neg's and set it to 2 cylinders. Then use a 2N5551 or similar transistor to drive the tacho.
Rick
Rick
Bit more involved, you need to open the case and feed the transistor from whichever point you assign in the software as the tach output.
deathrider666
Sep 28, 2015 06:12 PM
