2wd bits, ht leads, inlet manifold, plenum chamber etc
Old Aug 8, 2009 | 10:57 AM
john_p_b's Avatar
john_p_b
Default 2wd bits, ht leads, inlet manifold, plenum chamber etc
seeing as my rebuild is nearing an end now i have these parts no longer needed due to a change to omex management and coilpack conversion.
gen ford ht leads in black, perfect condition £40 delivered
2wd inlet manifold/plenum bought as a spare i was going to get bufty with but can't be arsed now £30 delivered
2wd plenum in mint condition just taken off as i've changed for a 4x4 item with spacer. £20 delivered
standard fuel pump, perfect working order £25 delivered
standard oil pump, made perfect pressure but have fitted a high pressure pump while i had the engine apart. £25 delivered.
standard 2 bar map sensor £15 delivered
c pillar trim, drivers side in ok condition, no cracks or broken bits but just a bit dull would probably clean up ok £12 delivered
radiator hose, in all honesty i'm not sure where it goes! just found it in a box but it's looking pretty mint really, genuine ford with ford clips so maybe one for the buftys? £12 delivered
Old Aug 8, 2009 | 11:21 AM
Rob Virgo's Avatar
Rob Virgo
hi john ,
ill have the gpa coil,delivery will be a little dearer to Ireland so let me know the difference.Do you know if its a genuine one (from good supplier)
r
Old Aug 8, 2009 | 11:24 AM
john_p_b's Avatar
john_p_b
came from Graham Goodes.
£2 on top to cover the postage ok?
Old Aug 8, 2009 | 11:52 AM
Rob Virgo's Avatar
Rob Virgo
cool,whats your paypal address
rob v
Old Aug 8, 2009 | 05:25 PM
lee2cossies's Avatar
lee2cossies
You have pm.
Old Aug 8, 2009 | 05:37 PM
john_p_b's Avatar
john_p_b
pm's replied to.
coil and throttle body now sold.
Old Aug 9, 2009 | 07:42 PM
john_p_b's Avatar
john_p_b
updated with pics and more bits added.
Old Aug 10, 2009 | 06:04 AM
snoopaloopa's Avatar
snoopaloopa
I'll take the headlight wipers mate, pm me your details
Old Aug 10, 2009 | 06:37 AM
john_p_b's Avatar
john_p_b
pm sent.
Old Aug 13, 2009 | 06:11 AM
john_p_b's Avatar
john_p_b
back up and open to sensible offers on everything.
Old Oct 11, 2009 | 09:50 PM
Taskforce's Avatar
Taskforce
Well it's Matt actually..
Hello
Still got that crank pulley available?
Old Oct 12, 2009 | 06:13 AM
john_p_b's Avatar
john_p_b
yep most of the above still available, not pushed them as been busy sorting my impending wedding out!
Old Dec 8, 2009 | 06:17 PM
tamjay34's Avatar
tamjay34
Default plenum fault code
i have a flat spot on my st170 and was told that it was down to the ecu for the lpg system needing a software upgrade.i went to get it done last week and they told me that the flat spot between 2 and 3000rpm was being caused by a fault with the plenum chamber.they werent sure wether it was down to a relay/control module or the flaps in the chamber.has anybody else come across this?i just need to know wether to try and source a new chamber or not.they cleared the faults but came back an hour later
Old Dec 10, 2009 | 10:31 AM
FordCapriRS's Avatar
FordCapriRS
Old Skool 4 Life
Default 2wd inlet mainfold
hi i am very interested in the inlet manifold how much was it £30 ill have that for that whats ur Paypal details pal
Old Dec 10, 2009 | 05:47 PM
john_p_b's Avatar
john_p_b
details pm'd
FlashRS
13
Aug 31, 2015 06:02 PM
Anutternutter
Aug 21, 2015 06:07 PM
Bailes1992
Aug 16, 2015 07:14 PM
mick pearson
Aug 9, 2015 09:19 AM
