VEMS wideband AFR
Old Aug 6, 2009 | 11:59 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
Default VEMS wideband AFR
had this for a while and as a standalone unit has been fine on my carb turbo setup, but now i'm getting efi running on megasquirt.
the problem is vems technical side is somewhat crap and i can't figure how to get it to communicate to my laptop through a usb com setup (which works with megasquirt).
i can't get a proper signal out of the wideband to help setup MS, all readings are way off.
just hopeful that someone else has used the same wideband, i know a few have had them, but not sure if they've done anything more than standalone, even datalogging would be nice.
cheers
sean
Old Aug 6, 2009 | 06:19 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i tried updating firmware, now it's fooked.
anyone know owt about these, i did a quick search and someone sold them a while back on here.
Old Aug 7, 2009 | 09:19 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
bump, it's only been a day, but it's now stopping me mapping my engine
Old Aug 7, 2009 | 12:07 PM
Chris69's Avatar
Chris69
have you posted up on the VEMS forum mate?
I have the VEMS AFR/egt guage but havn't used it for anything but a guage yet.
when i did have a problem switching between diplay modes they seemed quite helpful on the forum.
would be most appreciated if you post up your findings aswell as i plan to use megasquirt with my rst in the future
Old Aug 7, 2009 | 01:28 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i'm awaiting approval from the admin team, so i can't post yet sadly.
what i've found so far is that megatune needs to be a specific version to setup the wideband outputs and that the latest firmware isn't adviseable.
i'm going to try to force older firmware onto the wideband and then use a different version of megatune to get it to communicate.
until i get approval on the forum, that's all i can do sadly.
i'l keep this updated.
Old Aug 7, 2009 | 03:03 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
had to take the wideband out of the car and take home to pc, got it working now.
my first tip is to not use a laptop with a usb adaptor, not very reliable.
secondly, don't change firmware, it won't work afterwards lol!
the megatune that the forum links to is what you need, it's different from the one i use for my megasquirt and is specific for the wideband.
not worked much else out yet, but after 5 mins on the pc with it, it's good again.
Old Aug 7, 2009 | 08:40 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
piece of cake to setup to talk to ecu, once you update firmware with a known version, '08 is what i found to be best today, then you can use the right version of megatune and tell the wideband how you want the signal to be sent to ecu.
i'm usign a 0-5v signal as it gives better resolution.
Old Aug 9, 2009 | 08:35 PM
Chris69's Avatar
Chris69
great stuff cheers for the updates i'm gonna connect mine up soon have a fiddle with the megatune- nice to know it will connect up ok.
The Lambda output is a great feature to be able to use with the likes of megasquirt.
Chas
Oct 5, 2015 07:13 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Marino
Sep 12, 2015 11:10 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
Red_bull
Aug 25, 2015 06:27 PM
