Samco ancillries
Old Aug 6, 2009 | 09:04 AM
RSmark84's Avatar
RSmark84
Default Samco ancillries
Just brought the final samco hose set for my RS
its 3 hoses, i know the long thin one goes from the thermostat to the header tank, but the other 2 im not so sure......
the smallest one, im thinking 'Y' piece to bulkhead(heater matrix in)
the long bendy one bulkhead(heater matrix out) to bottom of themostat
is the above correct?
thanks
Old Aug 6, 2009 | 05:17 PM
moesin2005's Avatar
moesin2005
the thin one goes header tank to thermostat housing th one with the j shaped end goes from the thermostat housing to the heater matrix and the other is the oil return from the rocker cover to the back of the block but no good if u have a oil seperator
Old Aug 7, 2009 | 07:11 PM
RSmark84's Avatar
RSmark84
thank you for your reply.
steve.rst
Mar 15, 2016 08:01 AM
Chas
Oct 5, 2015 07:13 PM
Fudgey
21
Sep 30, 2015 06:19 PM
