Engine not running properly
Old Aug 5, 2009 | 09:15 PM
Martin//TwistedTuning's Avatar
Coyote
Angry Engine not running properly
Hi guys,
Just installed newman cams with the solid lifters, also got a port and polished head.
Fired it up today, to run the cam in.
But it sounds like its not firing properly or is running really rich!
Got the solid lifters set up as per Newman, and have also checked after this little running.
Im 90% sure all the sensor cables and sensors in the correct places! Maybe someone could list the colours and where they go for MFI turbo setup.
All the plugs are good, and have checked that they all have a good spark to them.
All the leads are good, and no cracks in dizzy at all.
When i timed the engine up, i set the crank at 114* After TDC, and set number 1 inlet valve at the fully open position. (number one being the pulley end) but not sure if this should be at dizzy end?
also played around with the timing and the fueling, but it didnt make much of a difference!
Any help for this would be greatly appreciated.
CheeRS
Martin
big_Rad
Sep 15, 2017 09:36 AM
Escortdriver1
Ford Focus RS Parts for Sale.
Aug 10, 2015 05:47 PM
Zoggon
Aug 10, 2015 10:39 AM
knight19770
Aug 4, 2015 12:36 PM
lockie
Jul 31, 2015 10:03 PM
