What Gearbox's will Fit a 80spec RS Turbo? without any mods
Apart from the standard LSD gearbox, which some RST's came with, what others will fit? without any modifications.. just a fit and go?
I need a new gearbox, and i am going for a different setup soon but still want to use the car to travel to shows and back. i need a gearbox at a good price, i dont wanna fork out 100s for a LSD as atm i cant afford it,
So what gearbox's fit? without any messing around. and more money being spent. as i need the cash for my new one im having started in sept.
1.6 XR3I box? i here you can get them cheap. but how cheap?
The only BUT in fitting just any mk3/mk4 box to a S2, is that IF it still uses the ABS, not all have gearbox cases have the mounting holes for the modualators.
well, it currently has a 1.8 D box and the ABS has not been removed yet. dont use it anymore
yea any box out a mk3 or 4 as carl says si u can get a lsd for 200 brand new up here surely its worth saving and spending a few quid more for the lsd i had diesel box on my cab and it was terrible 1 wheel drive all the way
