Boot carpet £25
spare wheel £25
tool kit and carpet cover £60
steering colum £125
steering cowlings top and bottom £25
rear prop shaft £100
plastic rear speaker holders which holds the parcel shelf £50 pair
carpet plastic retaining strips £20 pair
front grille £35
plastic front scuttle panel (were the wipers are) £20
full big turbo car loom front to back inc fuse box £400
steering wheel non air bag £75
charge cooler £40
rad fans £75
electric sunroof kit inc roof lining £125
pop out rear quarter window kit £100
no mate you will struggle to find either as no one will split the gaitor from the consul and no will will split a set of door cards
soory mate did'nt mean the door card.
i need the plastic trim on the sill that screws down inside the car to cover the edge of the carpet. if you know what i mean?
