Cosworth 2WD abs light stays on
Old Aug 4, 2009 | 05:07 PM
RS_Andy's Avatar
RS_Andy
Default Cosworth 2WD abs light stays on
Hi All,
Can i ask for some help and advise, ive been tinkering on the Cossie the last few weeks, and decided that the front Wheel bearing needed changing as there was a horrible knocking noise coming from the front right wheel.
The wheel bearings were changed all ok and now the noise has gone .
I had to remove the ABS sensors from the hubs when they were out i gave them a really good clean and cleaned the holes on the Hub where the sensors sit into. Since then my ABS light will not switch off when the car is started.
Before i did the hubs the ABS light inside did switch off ok.
Does that mean that i need new sensors - I can hear a whining when the car starts so i think the ABS unit is working.
I have a 1989 2WD Sapphire Cosworth.
Are you able to buy new sensors, and where can you get them from ?
Many thanks
Andy
Old Aug 4, 2009 | 05:11 PM
Kverna's Avatar
Kverna
Virgin-popper
Haha mine too. And this guys light
Stinky old fords http://www.youtube.com/watch?v=0Je8q...e=channel_page
original
Apr 28, 2026 05:20 PM
rdvil
Aug 15, 2015 12:11 PM
Aug 14, 2015 07:29 AM
Old ford
Jul 31, 2015 06:50 AM
