Q on the Idle setting on the ERST
Old Dec 16, 2004 | 06:53 PM
dave@swb's Avatar
dave@swb
Default Q on the Idle setting on the ERST
Mine seems to want to tick over at 500rpm, but it never stays running, which makes town driving a real pain in the arse.
On my 86 XR3i I used to have the idle was 750-900, is 500 right for the RS Turbo or do I need to up it.
If so... Then can I up it on the throttle body or cable or does it need to be done electriconically????
I need to get the rolling road'ed soon, is this something that the tuner will have to do???
Old Dec 16, 2004 | 08:26 PM
JesseT's Avatar
JesseT
Just screw the idle tuning screw on the throttle body.
Old Dec 20, 2004 | 06:25 PM
Exeter J's Avatar
Exeter J
Yeah they should - But as JesseT says just turn the idle screw slightly. Try Colin at Mad for It in Liskeard for the RR - as he is a bit of an ERST guru and has loadsa parts in stock. See www.mad-for-it.com
Old Dec 20, 2004 | 08:10 PM
radiant red's Avatar
radiant red
may be running rich, needs setting up properly mate
TPM961
Jan 15, 2018 10:50 AM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
3doorcozmess
Sep 7, 2015 01:32 PM
