people running 300+ bhp...
what headwork do you need to do to make the 300bhp mark?
also which injectors? (is it posible on 803's)?
which turbo? (can it be done on a t3 with a t34 compressor wheel?
thanks in advance !
thanks in advance !
i take it your doin a 1.6cvh? ported head newman cam double valve springs solid lifters,forged pistons an rods,803s at a push with a hybrid t3 turbo.the list is endless
Stage 3 big valve head is must as stock valves bottle neck at around 250bhp, Newmans cam i'd agree with but not double valve springs they specifically say not to use them! Even a Stage 3 T3 (48/55) would not flow enough for 300+bhp i'd look at something bigger! Dont know what 803's are good for. Pistons, rods, yup and arp bolts to hold it all together!
and my turbo is a stage 3 t3 and that is managing fine with 300.
Agree-bottom end must be steel rods and forged pistons though!
Interesting! Where was it Dyno'd?
NMS and APT have both told me that the standard valve size become restrictive at around 240-250bhp, and a Stage 3 T3 is only rated to 280bhp max!
Turbo Techincs website...
http://www.turbotechnics.com/docs/turbo/s107.htm
TURBO TECHNICS LIMITED
S107 Ford Escort RS Turbo Stage 3
Power output 210-280 BHP
standard valves are already big to start with mate,also i know a few people running st3 t3s running 320hp its a very good turbo,you can get the mahle pistons machined for lower comp they will run 350hp,but change the rods to steel,then you will run into gearbox issues if thats standard
mines a s1 head which i believe had the better valves to start with so maybe he was refering to a s2 head?
Stage 3 T3, 320bhp?
You DON'T know a FEW people with 320bhp, well, not on a CVH anyway. Not a PROPER 320bhp.
Sounds like I need to rethink my strategy. I'm obviously not trying hard enough.
sorry wot i should of said was ive heard of a few people running over 300+ on a st3 turbo obviously ringing its neck and standard sized valves are already big
if you phone turbo technics up they will tell you st3 turbo is good for 280hp but you can run more, if you run more you will damage the engine that is the reply i got from them
Ok perhaps some people believe it is possible........... maybe it is at an extreme push? Maybe some rollers say 'X'bhp and other 'Y'bhp.........but lets just say that it will be easier, and more reliable with a Stage 3 head and a bigger spec turbo, I think thats the best answer!
do agree dyno's are so out that they should only be regarded as an estimate of the power, things like ambient temps, barometric pressure, all play a big part.
well done christian you die hard cvh boys are really pushing the boundries now,saw your car at the fair sunday and like how you have the cage in the full interior,looks very tight bud.
Have you actually broke the 400bhp mark or are you just taking the piss out of Dyno accuracy??
I cant tell by your tone of voice?! lol
it is a 1600cvh. it has wosner 7-5-1 forged pistons,burton h-section steel conrods, oversized valves,ported and polished head and a piper 285t2 camshaft
which you will all be pleased to know i am getting rid of !! for sale if anyones intrested......
as im going for a newman cam with solid lifters . I've spoke to NMS and they have a custon cam & springs from newman that they say are the nuts? anyone have these?
still did 270 odd bhp tho.
as im going for a newman cam with solid lifters . I've spoke to NMS and they have a custon cam & springs from newman that they say are the nuts? anyone have these?Too many posts.. I need a life!!
