S2 shows battery light when i switch the ignition off?
Old Jul 31, 2009 | 05:10 PM
morph's Avatar
morph
Default S2 shows battery light when i switch the ignition off?
I have a major problem with my s2 in which i have replaced the battery twice, and the alternator twice because the battery kept going flat!
and now after all that the battery light has now started coming on after i turn the ignition off!
not too bothered but the following day the battery is flat and i need recharge the battery or jump it, tried removing the battery connector thinking it was that but that does not make a difference either! so now i am so pee'd off with the car and don't have a clue what to do. an electrician said that to investigate the problem he would charge by the hour and it may take allday! and his hourly charge is £50 quid! so told him to bother!
anyone had a similar problem?
Old Jul 31, 2009 | 05:13 PM
ricky_2006's Avatar
ricky_2006
you probably got a bad earth somewhere matey
Old Jul 31, 2009 | 05:16 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
normally thts caused by the alternator, the blue wire controls the light, ive never known it to be anything but sadly
van_dogg_pavvy
Mar 3, 2016 09:30 AM
3dr cossie
21
Nov 20, 2015 05:00 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
xr_craig
Aug 7, 2015 06:00 PM
