Just ordered my rods and turbo deceided
Arrows.....rated to 10000rpm
GT35 external wastegate...screamer pipe for running in..ROFL
Unfortunately i cant keep it like it as apparently doin a top speed run with it will alter the air turbulance under the car making it unstable....dont want to harm poor old Mike now do we
Aiming for 650bhp plus on race fuel and around 600bhp pump fuel.
Every other specification is secret and will remain that....as like all other big bhp boys we dont want everyone doin it,thats if i acheive it and it dont blow on the dyno
I read that bit about the car become unstable and had to bite my lip not to comment to be honest.
Its SO dependant on where you route it, and anyway you can always just plumb it back into the normal exhaust instead after the external gate instead of using it asa screamer pipe, if you are going to do that then i can see NO value of running it in on a screamer pipe instead. just more work for no gain.
What professionals told you that Phil? They obviously stupid
What about cars like, say, the Mazda 787B LeMans car, ALL the exhausts came out of one side, so why could that thing to 250mph no problemo?
Cause your talking bollocks
At full boost and high revs almost fuck all will come out the screamer pipe if your going for 600+ on a GT35 anyhow
You lot are chimps youy really are
Yeah as if i gonna run a pipe out the side on a road car
A bit dangerous?
So where would i have to run it to remain concealed?..So its pumping out under the car...so would interupt the flow of air there at 180 plus mph no?
Mike not at all...only on conrod choice as this is the weakest link...goodbye
A bit dangerous?
You'll have *all kinds* of swirling and flow reversal under there and unless you go to some sort of integrated 'flat bottom' or 'tunnel' setup.....you're just pissing in the wind worrying about it.
A bit dangerous?
Love the poo analogy
The big point you are missing is that the screamer pipe is where the gasses that bypass the turbo go, on a relatively smaller turbo and running your car flat out there wont be enough air coming out of that pipe to blow up a baloon let alone lift your cossie 6 foot in the air and induce a triple backflip.
If i speak to pros who say it can disturb the air enuff to cause slight instability at top speed runs then i beleive them as they been there DONE that
...Mikes safety is the most important thing as he is driving it....so i will er on the side of caution instead of listening to book worms!
Porkie how loud is it?????
It has nothing to do with books, it has to do with your lack of understanding of fluid flow.
Why not ask Mike if he'd drive it with the screamer pipe venting downward.
Not to mention that there should be NO flow through the pipe other than during shifts or overboost conditions, but I guess you've overlooked this or have a really shitty boost controller.
For someone with seemingly very little DEEP technical knowledge, you certainly do like to spew more than your share of bullshit.
Phil, would you please NAME the pro's that told you this stuff?
Or have they specifically told you that they dont want their name(s)
publically associated with your "DIY" project?
to EscortWRC..thanks for your words of wisdom....but would i be offending if i told you to talk to someone who gives a shit
With all the shit you talk/type im not surprised there is none left for you to give
YOU....offend ME.....not likely.....
Amuse, maybe....but not offend
Its always entertaining to see you pretend to know things that you don't and back pedal when you get called on it by someone who does know.
Its not like I'm an aero engineer or anything......
Whats the point of mentioning it on a DISCUSSion forum if you "dont give a shit" what others say?
Why not just register
www.phils-little-world.com
and publish it all on there where no can an argue with you?
Originally Posted by MattRS1600i
I reckon he's gonna produce a quick car.
oh and after EscortWRC last reply i think phil deserves a
"cap in yo arse!"
...I am truly not worthy
