fuel gauge
hi all
got a s2 and fuel gauge sticks half way if i put fuel in it does rise but never goes lower than half way . is there a way i can test if it the gauge or sender and second does any body know were the reverse switch is on the gear box as reverse lights wont work. ive checked fuses , bulbs and still nothing
thanks daz
.thanks daz
reverse light switch is on the front of the gearbox, black 2 pin round plug goes onto it.
Fuel guage, if you un plug it, if its the sender the guage will then go right down, if it stays where it is, its the guage.
plug should be under your rear seat, will also be one for the fuel pump, heavier wired one is for the pump.
Mark RS
Oct 12, 2015 06:01 AM
