cosworth 2wd engine for sale offers
ok guys
i got this engine about 2weeks ago for my mk2 escort
ive stripped it down cleaned it
sent the head off to be stripped clean, replaced anything that needed to be replaced
and have now rebuilt it
but i have had the chance to buy a brand new cosworth engine still in the box from ford
so this fresh engine is up for sale
you get a
cosworth 2wd
205 block
3door head
2wd sump
new gaskets and head bolts, core plugs and oil filter
this is a turbo engine and comes complete with standard t3 turbo
also inlet manifold plus plenum
also dizzy and leads
the block has been painted black
here are some pics of if before strip down
i am not sure what its worth ive seen them go for £2000 with out the manifolds plus turbo
looking for around £2000 for everything or offers
paul
07515743167
essex
you get a
cosworth 2wd
205 block
3door head
2wd sump
paul
07515743167
essex
I'm waiting to get it back once I have it home I'll take pictures
Sump cleaned
pick up removed cleaned and replaced
new sump gaskets
bottom end all checked everything is good so nothing replaced
new oil filter
new head gasket
head removed
head stripped down cleaned
new vale Gide seals
vales removed checked polished replaced
new core plugs
I will check what else was replaced as work do by engine builders
block painted black
red top rocker cover
Any more info please just ask and I'll try and help
Need engine gone by Wednesday
Sump cleaned
new sump gaskets
new oil filter
new head gasket
head removed
new vale Gide seals
new core plugs
block painted black
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
