cosworth engine broken down 200 block new prices
Old Jul 29, 2009 | 08:05 PM
demonweeks's Avatar
demonweeks
Default cosworth engine broken down 200 block new prices
complete engine been broken down this was a sweet sounding engine only covering 12k from full rebuild,
complete 2wd head messures 138mm slight marks on face £300
crankshaft standard big ends(just been polished) .25 mains(freshly ground) £300
set of low comp mahle pistons belive first over size (91.275) with valve cut outs with rods £250
200 block ment to be mountune? cooper ringed has a hair line crack by one of the bolt holes have been told no scrap as can be long studed? £250ono
2wd sump £60ono
2wd mainifold £70
alternater works fine bearings sound little dry £25
rocker cover in blue £60
2wd pump worked fine complete with pick up £30
2wd inlet/plenum £50
have all other bits fuel rail,standard injectors, hoses etc pm for more details and my number. Russ
Last edited by demonweeks; Aug 16, 2009 at 04:15 PM. Reason: new bits added and prices canged and ford fair gone
Old Jul 29, 2009 | 08:42 PM
cossiedave's Avatar
cossiedave
you have pm m8
Old Jul 29, 2009 | 08:57 PM
Simmo's Avatar
Simmo
You have pm
Old Aug 16, 2009 | 05:06 PM
demonweeks's Avatar
demonweeks
more parts added to list
Old Aug 16, 2009 | 05:14 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
pm sent milaaaaad
Old Aug 16, 2009 | 05:19 PM
Ben M's Avatar
Ben M
hello and welcome mate
Old Aug 16, 2009 | 07:29 PM
janvanv's Avatar
janvanv
www.rallyanarchy.com
Hi I need the front seal plate, the cam belt pulley and the guide washer.
My machine shop says they seemed to have crawled away while getting cleaned and sorta need them to finish this motor I'm building.
Please let me know.
Thanks
big_Rad
Sep 15, 2017 09:36 AM
EoinXR3
Sep 7, 2015 05:44 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
