Escos parts CHEAP (S1,Rsi and more also)
Old Jul 29, 2009 | 09:15 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Default Escos parts CHEAP (S1,Rsi and more also)
Hi all Ive decided I need to get rid of my 10 years worth of RS hoardings. Just taking up too much valuable space.
All parts are sold as seen.
I will be as exact as is possible in my descriptions, as said some of these parts I havn't even looked at in 10 years so im a bit rusty on remembering their exact condition. Therefore if im not sure, condition will be marked as UNKNOWN. Bearing this in mind I am pricing everything very reasonably, as id like shot of it all to make room for new projects.
Any questions please just ask, and if more detailed pics are needed then Its not a problem.
All items can be posted at additional cost, but would prefer pick up only.
As for payment, again cash would be best. I have Paypal but as you know fees take the piss, especially as im selling the parts dirt cheap!
Right here goes
IM AT FORD FAIR SUNDAY IF ANYONE IS THERE
Escort Cosworth: (priced individually or the lot £10)
Clear Front Indicators, rear clips are damaged, but lights still perfectly useable £2
Steering rack UJ, rubber bush has wear, but easily replaced, 2nd hand is price usually £30-40. £2
Under bonnet matting , good with no rips and heat foil still in place £2
Rad and air con rad, Pipes included, condition is unknown £5
Series One RST: (priced individually Or the lot for £68!!!)
Amal valve, including pipes £2
Steering Wheel Center Cap £2
Fuel Relay, brown mark on one of the tabs but looks ok and no smell £1
Sun Roof Glass, Very good condition, about 1/2" rust patch under glass as can be expected on these. £5
Metering unit, come with mounting base, was on my S1 so fully working to best of my knowledge £10
Intercooler, fins not in good condition, cond unknown, ideal for rebuild
£2
Genuine Ford Indicator, Off side/Right hand, mounting clips ok £2
Rear bumper trim cap, Off side/Right hand side £2
Rear bumper trim cap, Near side/Left hand side £2
Stainless turbo heat shield, Gruby but will polish up fine £1
Door Cards, Very good with no rips, will clean up easily, left and right. £2
Rear bench back, missing plastic belt rings, no rips £2
Rear bench back, no rips £5
Rear bench back, rare as it is a one piece, not 1/3 as usual, sadly only cloth and foam its missing rear metal back, but may be of use for retrimming, cloth has no rips £2
Rear bench seat, no rips, good condition base £5
Carpet, small cut on rear off side foot well, but not noticable, dirty but should clean up nicley with a decent shampoo £2
Mk3 Under bonnet matting, has slight wear, but still smart, people usualy spray them with matt black spray to tidy up. £1
Boot rear 1/4 cover trim and sound matting , £2
Alloy, tyre not legal, £2
Fuel tank, good condition, will need a clean and repaint but perfectly useable, £2
"Cosworth" style grill, intresting cira 1990's grill, one on ebay for £40 at the mo!!! £2
Kick Plates, both sides, one has very small unnoticable crack, one has has a small hole cut for speaker wire, but think this is covered buy speaker grille. easily repaired tho £2
Speaker grille, near side/left hand very good condition. £2
Stainless Sill plates, pair £2
Rear bumper, surface rust only, nice genuine ford metal from 1985 S1, so no worry about shit fitment with pattern ones £2
Lower gear box mounts, front and rear, £2
Front bumper trim cap, Off side/Right hand side £2
RS1600i: (priced individually or the lot for £145)
(I have a full seat set and door card/caps, but not sure if i want to sell yet)
Alloy, £3
Rads, Pair of rads, as far as I know both are ok, one fan motor is fubard, should be able to make 1 good rad out of the 2. £2
Sunroof, plastic lugs on glass part are broken, glass is very good with no rust under it, pic is bad but i will clean it up and post new pic, also comes with mechanism which is ok. £2
Door Mirror, Off side/Right hand, metal adjustment lever is broken, but glass and plastic in a1 condition, £2
Suspension, useable, but more suited to get a shell rolling during restoration, £3
Head, genuine RSi head, good condition. was going to rebuild and keep as spare, but surplus to requirments now.£50
Cam shaft, genuine ford, very good condition £10
I have a set of brand new Kent Cams Solid Lifters, special to the RSi to go with this, but not sure if im selling them yet?
Flywheel, genuine RSi and hard part to find if wanting to run twin coils. Magnetic strip in good working condition, £50
Front bumper trim strip, Near side/Left hand side £2
Front bumper trim strip, Off side/Right hand side £2
Head bolts, unused stretch bolts never torqued. Didnt use as I bought a set of non stretch bolts from butons £2
Accelerator Cable, very good condition £2
Throttle Boddy, hard to find RSI straight body only, xr3i ones are angled. £2
Brake Resovir (sp) This was donated to me and my fire project, so its only fair that I donate it to some elses cause. £0
Wiper mech, condition unknown, will need new plastic washers. £2
Brand NEW Steering rack boot, £2
Bonnet pull, conduit is not perfect, but cable works fine. £1
Speedo cable, missing white clip but conduit is in as new condition £2
Thermostat housing, needs a clean £1
MK 1 Escort:
Wing, 3 wheel trims, 1 wheel ring, chrome alliminum window sides, Wing has dent and surface rust but useable with a bit of effort £2
Mk4 Escort:
CVH engine mount, suit RST or any CVH, very very good condition. £2
Rocker cover £1
Rocker cover, come with head bolts, condition unknown £2
Mk5/6 Diesel:
BRAND NEW BOXED GENUINE Ford 1.8 diesel rad, fits van and car, cost £90 new. £10
Old Jul 29, 2009 | 09:55 AM
zetecturbo's Avatar
zetecturbo
hi mate il ahve the escos stuff u got paypal
Old Jul 29, 2009 | 10:13 AM
maxest's Avatar
maxest
Some bargains there fair play, i wouldnt have gone to the effort for such low value parts, but they'll be some things there people really want
Old Jul 29, 2009 | 12:23 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Pm'd mate
Escos stuff Provisionally sold!
Old Jul 29, 2009 | 12:25 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
It was either make a bit of beer money or throw it all in the skip.
£100's worth of stuff here but i simply want shot of it, At least this way it goes quick and people cant exactly complain at this price.
Old Jul 29, 2009 | 04:28 PM
Cosmo's Avatar
Cosmo
PM'd you mate
Old Jul 29, 2009 | 06:47 PM
TrevCos's Avatar
TrevCos
Lots of real good bargains there mate.
Old Sep 30, 2009 | 02:10 PM
del1boy-2008's Avatar
del1boy-2008
Del1boy
Alrite mate,
I have a H Reg Escort RS Turbo, Would your rad fit in it???
Thanks Del
Old Sep 30, 2009 | 02:31 PM
massivewangers's Avatar
massivewangers
YHPM
155lee
Sep 6, 2016 11:10 AM
Fudgey
Sep 17, 2015 01:06 PM
gcfcos
Sep 11, 2015 06:03 PM
Mickeystewart
Sep 9, 2015 04:04 PM
