Bailey breather question
Old Mar 1, 2004 | 09:04 AM
Default Bailey breather question
When fitting a bailey breather kit onto a 4x4 cos does it connect onto the standard oil seperator (black metal box under manifold)or does the new system do away with it?
Has anyone got a diagram on where all the pipe work goes to.
Roy.
Old Mar 1, 2004 | 01:57 PM
Milko's Avatar
Milko
Yeah, your meant to slide in 1 of the alloy pipes but its a proper tight fit so we ended up using the standard ford rubber elbow, putting the pipe into that, then the elbow back on the metal box type thing, brings the pipe out up the back but makes no difference.
If you've got July 2002 FastFord, there is an article on how its all done.
Old Mar 2, 2004 | 05:21 PM
Dave Henshall's Avatar
Dave Henshall
if anyone has this scanned i would also much appreciate it
Old Mar 2, 2004 | 05:31 PM
Milko's Avatar
Milko
Will av ago at scanning it later, am not that good with these things tho!
Old Mar 2, 2004 | 05:43 PM
Dave Henshall
would be v thankfull - - looking at the job - it looks as if breathering ftom both sides of the block is the better way to go rather than breathing from one side and the rocker box - before i pull it all to bits though im gonna make sure i have all the bits, pipes and clips ands stuff.
cheers, dave.
Old Mar 2, 2004 | 05:49 PM
Milko's Avatar
Milko
Minr breathers both sides and rocker top!
Old Mar 3, 2004 | 07:52 AM
Dave Henshall
so does the big vent to atmosphere and the small oil return go to where the oil return went in place if the std ford oil seperator oil return?
Old Mar 3, 2004 | 01:45 PM
Milko's Avatar
Milko
Dint get that m8
Big un under tank breathes to atmostphere, little un underneath breathes/drains to sump, 1 of the top uns goes to rocker, other top un goes to original breather point under inlet manifold.
Old Mar 3, 2004 | 03:56 PM
Dave Henshall
scans came though - and show where it all means - cheers mate
Old Mar 5, 2004 | 09:04 AM
Can you mail me a copy,need to see pics
Old Mar 5, 2004 | 09:14 AM
Dave Henshall
pm me your email addrss and ill send them now
Old Mar 6, 2004 | 06:14 PM
Sent you a pm Dave
Old Mar 7, 2004 | 03:27 PM
Dave Henshall
im at home at the moment - will send them monday morning from work
Old Mar 8, 2004 | 08:41 PM
Dave Henshall
ladies and gents - you should have recieved them today
if anyone else wants a copy - pm me
cheers to Milko for the scans
Old Mar 9, 2004 | 07:57 PM
Speedy G.'s Avatar
Speedy G.
Thank you very much for them mails m8.
Old Mar 14, 2004 | 02:18 PM
Would also love a copy Dave
John.g.bennett@btinternet.com
Old Mar 14, 2004 | 02:21 PM
Dave Henshall
SENT
Old Mar 14, 2004 | 05:49 PM
Can you mail me also a copy
nadia.nulens@pandora.be
Old Mar 15, 2004 | 07:49 AM
Dave Henshall
sent, and sent
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
